Joplin Settings Page Error
Hi all, I've been using Joplin for quite a while now and have loved every moment... except I've encountered my first major error and need some help sorting it out.
I'm not longer able to enter the settings as an error is thrown up and since I use Joplin extensively for most things, including work, I really am worried that it might put my notes at risk. The error message is below, any help is really appreciated.
Error
Joplin encountered a fatal error and could not continue. To report the error, please copy the entire content of this page and post it on Joplin forum or GitHub.
Message
md.options is not a function
Version info
Joplin for Desktop
Copyright © 2016-2021 Laurent Cozic
Joplin 1.6.7 (prod, linux)
Client ID: 0ab5addc261b442fa759f1496bcd3ec9
Sync Version: 2
Profile Version: 34
Keychain Supported: No
Revision: b74b849 (master)
Stack trace
TypeError: md.options is not a function
at ConfigScreenComponent.settingToComponent (/tmp/.mount_JoplinSKnYiK/resources/app.asar/gui/ConfigScreen/ConfigScreen.js:331:39)
at createSettingComponents (/tmp/.mount_JoplinSKnYiK/resources/app.asar/gui/ConfigScreen/ConfigScreen.js:144:42)
at ConfigScreenComponent.sectionToComponent (/tmp/.mount_JoplinSKnYiK/resources/app.asar/gui/ConfigScreen/ConfigScreen.js:149:30)
at Object.shared.settingsToComponents2 (/tmp/.mount_JoplinSKnYiK/resources/app.asar/node_modules/@joplin/lib/components/shared/config-shared.js:184:28)
at ConfigScreenComponent.render (/tmp/.mount_JoplinSKnYiK/resources/app.asar/gui/ConfigScreen/ConfigScreen.js:528:37)
at finishClassComponent (/tmp/.mount_JoplinSKnYiK/resources/app.asar/node_modules/react-dom/cjs/react-dom.development.js:17039:31)
at updateClassComponent (/tmp/.mount_JoplinSKnYiK/resources/app.asar/node_modules/react-dom/cjs/react-dom.development.js:16994:24)
at beginWork$1 (/tmp/.mount_JoplinSKnYiK/resources/app.asar/node_modules/react-dom/cjs/react-dom.development.js:18505:16)
at HTMLUnknownElement.callCallback (/tmp/.mount_JoplinSKnYiK/resources/app.asar/node_modules/react-dom/cjs/react-dom.development.js:347:14)
at Object.invokeGuardedCallbackDev (/tmp/.mount_JoplinSKnYiK/resources/app.asar/node_modules/react-dom/cjs/react-dom.development.js:397:16)
Component stack
in ConfigScreenComponent (created by Connect(ConfigScreenComponent))
in Connect(ConfigScreenComponent) (created by NavigatorComponent)
in div (created by NavigatorComponent)
in NavigatorComponent (created by Connect(NavigatorComponent))
in Connect(NavigatorComponent) (created by RootComponent)
in ThemeProvider (created by RootComponent)
in StyleSheetManager (created by RootComponent)
in RootComponent (created by Connect(RootComponent))
in Connect(RootComponent)
in ErrorBoundary
in Provider
This has been fixed, you just need to update Joplin. Your version is outdated.
