os: macOS 13.0 Ventura
Error
Joplin encountered a fatal error and could not continue.
To report the error, please copy the entire content of this page and post it on Joplin forum or GitHub.
If the error persists you may try to restart in safe mode, which will temporarily disable all plugins.
Message
editor.setMode is not a function
Version info
Joplin for Desktop
Copyright © 2016-2022 Laurent Cozic
Joplin 2.9.17 (prod, darwin)
Client ID: 1adba60e796a40d8a6bbb30713ed42aa
Profile Version: 41
Revision: e5d379233 (dev)
Stack trace
TypeError: editor.setMode is not a function
at /Applications/Joplin.app/Contents/Resources/app.asar/gui/NoteEditor/NoteBody/TinyMCE/TinyMCE.js:487:16
at commitHookEffectListMount (/Applications/Joplin.app/Contents/Resources/app.asar/node_modules/react-dom/cjs/react-dom.development.js:23150:26)
at commitPassiveMountOnFiber (/Applications/Joplin.app/Contents/Resources/app.asar/node_modules/react-dom/cjs/react-dom.development.js:24926:13)
at commitPassiveMountEffects_complete (/Applications/Joplin.app/Contents/Resources/app.asar/node_modules/react-dom/cjs/react-dom.development.js:24891:9)
at commitPassiveMountEffects_begin (/Applications/Joplin.app/Contents/Resources/app.asar/node_modules/react-dom/cjs/react-dom.development.js:24878:7)
at commitPassiveMountEffects (/Applications/Joplin.app/Contents/Resources/app.asar/node_modules/react-dom/cjs/react-dom.development.js:24866:3)
at flushPassiveEffectsImpl (/Applications/Joplin.app/Contents/Resources/app.asar/node_modules/react-dom/cjs/react-dom.development.js:27039:3)
at flushPassiveEffects (/Applications/Joplin.app/Contents/Resources/app.asar/node_modules/react-dom/cjs/react-dom.development.js:26984:14)
at /Applications/Joplin.app/Contents/Resources/app.asar/node_modules/react-dom/cjs/react-dom.development.js:26769:9
at workLoop (/Applications/Joplin.app/Contents/Resources/app.asar/node_modules/scheduler/cjs/scheduler.development.js:266:34)
Component stack
at TinyMCE (/Applications/Joplin.app/Contents/Resources/app.asar/gui/NoteEditor/NoteBody/TinyMCE/TinyMCE.js:92:54)
at div
at div
at div
at NoteEditor (/Applications/Joplin.app/Contents/Resources/app.asar/gui/NoteEditor/NoteEditor.js:58:68)
at ConnectFunction (/Applications/Joplin.app/Contents/Resources/app.asar/node_modules/react-redux/lib/components/connect.js:246:87)
at div
at I (/Applications/Joplin.app/Contents/Resources/app.asar/node_modules/styled-components/dist/styled-components.cjs.js:1:19344)
at div
at div
at ResizableLayout (/Applications/Joplin.app/Contents/Resources/app.asar/gui/ResizableLayout/ResizableLayout.js:46:45)
at div
at MainScreenComponent (/Applications/Joplin.app/Contents/Resources/app.asar/gui/MainScreen/MainScreen.js:74:9)
at div
at NavigatorComponent (/Applications/Joplin.app/Contents/Resources/app.asar/gui/Navigator.min.js:9:1)
at exports.ThemeProvider (/Applications/Joplin.app/Contents/Resources/app.asar/node_modules/styled-components/dist/styled-components.cjs.js:1:25041)
at ae (/Applications/Joplin.app/Contents/Resources/app.asar/node_modules/styled-components/dist/styled-components.cjs.js:1:13420)
at RootComponent (/Applications/Joplin.app/Contents/Resources/app.asar/gui/Root.js:103:1)
at ErrorBoundary (/Applications/Joplin.app/Contents/Resources/app.asar/gui/ErrorBoundary.js:21:9)
at Provider (/Applications/Joplin.app/Contents/Resources/app.asar/node_modules/react-redux/lib/components/Provider.js:19:3)
