const moment = require('moment');
import time from './time';
const { FsDriverDummy } = require('./fs-driver-dummy.js');
const { sprintf } = require('sprintf-js');
const Mutex = require('async-mutex').Mutex;
const writeToFileMutex_ = new Mutex();
export enum TargetType {
Database = 'database',
File = 'file',
Console = 'console',
export enum LogLevel {
None = 0,
Error = 10,
Warn = 20,
Info = 30,
Debug = 40,
interface TargetOptions {
level?: LogLevel;
database?: any;
console?: any;
prefix?: string;
path?: string;
source?: string;
// Default message format
format?: string;
// If specified, will use this as format if it's an info message
formatInfo?: string;
interface Target extends TargetOptions {
type: TargetType;
export interface LoggerWrapper {
debug: Function;
info: Function;
warn: Function;
error: Function;
class Logger {
// For backward compatibility
public static LEVEL_NONE = LogLevel.None;
public static LEVEL_ERROR = LogLevel.Error;
public static LEVEL_WARN = LogLevel.Warn;
public static LEVEL_INFO = LogLevel.Info;
public static LEVEL_DEBUG = LogLevel.Debug;
public static fsDriver_: any = null;
private static globalLogger_: Logger = null;
private targets_: Target[] = [];
private level_: LogLevel = LogLevel.Info;
private lastDbCleanup_: number = time.unixMs();
private enabled_: boolean = true;
static fsDriver() {
if (!Logger.fsDriver_) Logger.fsDriver_ = new FsDriverDummy();
return Logger.fsDriver_;
public get enabled(): boolean {
return this.enabled_;
public set enabled(v: boolean) {
this.enabled_ = v;
public static initializeGlobalLogger(logger: Logger) {
this.globalLogger_ = logger;
public static get globalLogger(): Logger {
if (!this.globalLogger_) throw new Error('Global logger has not been initialized!!');
return this.globalLogger_;
static create(prefix: string): LoggerWrapper {
return {
debug: (...object: any[]) => this.globalLogger.log(LogLevel.Debug, prefix, ...object),
info: (...object: any[]) => this.globalLogger.log(LogLevel.Info, prefix, ...object),
warn: (...object: any[]) => this.globalLogger.log(LogLevel.Warn, prefix, ...object),
error: (...object: any[]) => this.globalLogger.log(LogLevel.Error, prefix, ...object),
public setLevel(level: LogLevel) {
const previous = this.level_;
this.level_ = level;
return previous;
level() {
return this.level_;
targets() {
return this.targets_;
addTarget(type: TargetType, options: TargetOptions = null) {
const target = { type: type };
for (const n in options) {
if (!options.hasOwnProperty(n)) continue;
(target as any)[n] = (options as any)[n];
this.targets_.push(target);
objectToString(object: any) {
let output = '';
if (typeof object === 'object') {
if (object instanceof Error) {
object = object as any;
output = object.toString();
if (object.code) output += `\nCode: ${object.code}`;
if (object.headers) output += `\nHeader: ${JSON.stringify(object.headers)}`;
if (object.request) output += `\nRequest: ${object.request.substr ? object.request.substr(0, 1024) : ''}`;
if (object.stack) output += `\n${object.stack}`;
} else {
output = JSON.stringify(object);
} else {
output = object;
return output;
objectsToString(...object: any[]) {
const output = [];
for (let i = 0; i < object.length; i++) {
output.push(`"${this.objectToString(object[i])}"`);
return output.join(', ');
static databaseCreateTableSql() {
const output = `
CREATE TABLE IF NOT EXISTS logs (
id INTEGER PRIMARY KEY,
source TEXT,
level INT NOT NULL,
message TEXT NOT NULL,
\`timestamp\` INT NOT NULL
return output.split('\n').join(' ');
// Only for database at the moment
async lastEntries(limit: number = 100, options: any = null) {
if (options === null) options = {};
if (!options.levels) options.levels = [LogLevel.Debug, LogLevel.Info, LogLevel.Warn, LogLevel.Error];
if (!options.levels.length) return [];
for (let i = 0; i < this.targets_.length; i++) {
const target = this.targets_[i];
if (target.type === 'database') {
let sql = `SELECT * FROM logs WHERE level IN (${options.levels.join(',')}) ORDER BY timestamp DESC`;
if (limit !== null) sql += ` LIMIT ${limit}`;
return await target.database.selectAll(sql);
return [];
targetLevel(target: Target) {
if ('level' in target) return target.level;
return this.level();
public log(level: LogLevel, prefix: string, ...object: any[]) {
if (!this.targets_.length || !this.enabled) return;
const targetPrefix = prefix ? prefix : target.prefix;
if (this.targetLevel(target) < level) continue;
if (target.type === 'console') {
let fn = 'log';
if (level === LogLevel.Error) fn = 'error';
if (level === LogLevel.Warn) fn = 'warn';
if (level === LogLevel.Info) fn = 'info';
const consoleObj = target.console ? target.console : console;
let items: any[] = [];
if (target.format) {
const format = level === LogLevel.Info && target.formatInfo ? target.formatInfo : target.format;
const s = sprintf(format, {
date_time: moment().format('YYYY-MM-DD HH:mm:ss'),
level: Logger.levelIdToString(level),
prefix: targetPrefix || '',
message: '',
items = [s.trim()].concat(...object);
} else {
const prefixItems = [moment().format('HH:mm:ss')];
if (targetPrefix) prefixItems.push(targetPrefix);
items = [`${prefixItems.join(': ')}:`].concat(...object);
consoleObj[fn](...items);
} else if (target.type === 'file') {
const timestamp = moment().format('YYYY-MM-DD HH:mm:ss');
const line = [timestamp];
if (targetPrefix) line.push(targetPrefix);
line.push(this.objectsToString(...object));
// Write to file using a mutex so that log entries appear in the
// correct order (otherwise, since the async call is not awaited
// by caller, multiple log call in a row are not guaranteed to
// appear in the right order). We also can't use a sync call
// because that would slow down the main process, especially
// when many log operations are being done (eg. during sync in
// dev mode).
let release: Function = null;
// eslint-disable-next-line promise/prefer-await-to-then -- Old code before rule was applied
writeToFileMutex_.acquire().then((r: Function) => {
release = r;
return Logger.fsDriver().appendFile(target.path, `${line.join(': ')}\n`, 'utf8');
}).catch((error: any) => {
console.error('Cannot write to log file:', error);
}).finally(() => {
if (release) release();
} else if (target.type === 'database') {
const msg = [];
if (targetPrefix) msg.push(targetPrefix);
msg.push(this.objectsToString(...object));
const queries = [
sql: 'INSERT INTO logs (`source`, `level`, `message`, `timestamp`) VALUES (?, ?, ?, ?)',
params: [target.source, level, msg.join(': '), time.unixMs()],
const now = time.unixMs();
if (now - this.lastDbCleanup_ > 1000 * 60 * 60) {
this.lastDbCleanup_ = now;
const dayKeep = 14;
queries.push({
sql: 'DELETE FROM logs WHERE `timestamp` < ?',
params: [now - 1000 * 60 * 60 * 24 * dayKeep],
target.database.transactionExecBatch(queries);
error(...object: any[]) {
return this.log(LogLevel.Error, null, ...object);
warn(...object: any[]) {
return this.log(LogLevel.Warn, null, ...object);
info(...object: any[]) {
return this.log(LogLevel.Info, null, ...object);
debug(...object: any[]) {
return this.log(LogLevel.Debug, null, ...object);
static levelStringToId(s: string) {
if (s === 'none') return LogLevel.None;
if (s === 'error') return LogLevel.Error;
if (s === 'warn') return LogLevel.Warn;
if (s === 'info') return LogLevel.Info;
if (s === 'debug') return LogLevel.Debug;
throw new Error(`Unknown log level: ${s}`);
static levelIdToString(id: LogLevel) {
if (id === LogLevel.None) return 'none';
if (id === LogLevel.Error) return 'error';
if (id === LogLevel.Warn) return 'warn';
if (id === LogLevel.Info) return 'info';
if (id === LogLevel.Debug) return 'debug';
throw new Error(`Unknown level ID: ${id}`);
static levelIds() {
return [LogLevel.None, LogLevel.Error, LogLevel.Warn, LogLevel.Info, LogLevel.Debug];
export default Logger;
