Joplin for Android To Do. Have to keep typing the - [ ]
To report a bug, please let us know:
  • The version you are using. 1.0.336
  • The operating system you are using. Android 10 on a Galaxy S9
When adding a task in the desktop app in the editable column when you press enter it automatically adds the - [ ]
When you press enter in the Android app you have to always type the - [ ] which is obviously quite tedious if you have many things to add especially on a small phone screen keyboard.
Is there an easier way to do it? It is too hard to work with on the Android app when you have to keep typing - [ ]
Many thanks.
I would also like to see this feature for the task list with "- [ ]" as for the normal list "-".
Depending on what keyboard you use on Android, you can make a shortcut workaround. For example on Gboard I've assigned the shortcut td to write - [ ] for to-do.
And others, for example, iml for image link to write ![ ]( ), hl to write *** for horizontal line, etc. Using shortcuts that make sense to you.
I would love to see this feature added to the Android app as well.
