Joplin automatically syncs with WebDAV although disabled
What could be the reason that even if I have disabled the sync interval, Joplin automatically syncs with WebDAV within 2 minutes if I have changed something on a note? It seems that setting the interval has no effect. Is this the intended behavior? Then what is the point of defining an interval?
Joplin 2.8.8 (prod, win32)
Windows 10
This is clarified in an old post.
If you don't want to synchronise, you now have the option to select "None" as sync target.
I wanted to synchronize, but only with CTRL+s or with interval.
But I see I have to get used to it.
I still don't understand the reason for the interval when it is also synced on every change :man_shrugging:
Thank you for your explanation.
