Joplin android file system
Android
Joplin 3.1.7 (prod, android)
Client ID: 35e2877fb39b4a61bdac97e992dda095
File system
new setup. on android,
under sync target, selected file system
i'm not able to select a network location, just the android device and sd card
on the desktop version I'm able to select a network location
You need a 3rd party app in order to do that. For example, depending on the type of your network storage, something like https://github.com/wa2c/cifs-documents-provider.
That did the trick! Thank you!
