kastor
19 December 2020 15:12
1
Hello support,
I've just installed (1.4.19) via the script
wget -O - https://raw.githubusercontent.com/laurent22/joplin/dev/Joplin_install_and_update.sh | bash
I see .joplin folder and Joplin.AppImage inside.
When I want to start Joplin by the menu or by double click on Joplin.AppImage nothing append !
Might I suggest chmod +x Joplin.AppImage?
Merry, installed MX linux, funny little distro.
Downloaded Joplin with your command and executed it via file browser. Everything runs normal.
Did you apt update && apt upgrade -y?
kastor
21 December 2020 18:43
5
Not better
I don't really understand why ; I run on this PC other .AppImage without trouble
I see nothing in the task manager
eagle
21 December 2020 20:32
6
Can you try:
Click on MX "starter" at the bottom left side.
Type Joplin and the right click on the Joplin icon. Select "Edit application" (I think, I don't use English MX).
Edit the "command" by adding --no-sandbox like this example :
/home/user/.joplin/Joplin.AppImage --no-sandbox
After saving, try to start Joplin using that icon.
kastor
22 December 2020 05:19
7
alleluia !
It works. Thank you very much.
Congratulations also for the job you did with this application. I use it everyday.
Have a nice day
kastor
eagle
22 December 2020 08:11
8
Good you got it sorted, kastor.
I am just another happy Joplin user and i learned the --no-sandbox trick from another message thread here.
By the way, now I use MX-19.3 ahs ("Advance Hardware Support edition") and for some reason there we do not have to use --no-sandbox anymore. Joplin runs fine out of the box on 19.3 ahs.
kastor
22 December 2020 08:25
9
Hello cozic,
I also using MX19.3
System:
Host: Kernel: 4.19.0-6-amd64 x86_64 bits: 64 compiler: gcc v: 8.3.0
parameters: BOOT_IMAGE=/boot/vmlinuz-4.19.0-6-amd64
root=UUID= ro quiet splash
Desktop: Xfce 4.14.2 tk: Gtk 3.24.5 info: xfce4-panel wm: xfwm4
dm: LightDM 1.26.0 Distro: MX-19.3_x64 patito feo February 15 2020
base: Debian GNU/Linux 10 (buster)
eagle
22 December 2020 08:59
10
Hi kastor
As you see below my 19.3 ahs version use a much newer kernel. I was adviced to switch to the ahs version to get my USB-C monitor to work with MX Linux. The ahs version has better support for newer hardware.
Now we are straying away from the subject of Joplin....
System: Host: <filter> Kernel: 5.8.0-3-amd64 x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/boot/vmlinuz-5.8.0-3-amd64
root=UUID=<filter> ro quiet splash
Desktop: Xfce 4.14.2 tk: Gtk 3.24.5 info: xfce4-panel wm: xfwm4 dm: LightDM 1.26.0
Distro: MX-19.3_ahs_x64 patito feo November 11 2020
kastor
22 December 2020 09:12
11
cozic,
thank you for the ahs information. I'll look after that.
Have a nice day
kastor
