Issue with userstyle.css (solved, found out why)
userstyle.css won’t work unless the encoding is set to UTF-8.
If the encoding of userstyle.css were ANSI or Unicode, the temporary css generated and actually applied to the markdown render is padded out with empty spaces for letter by letter, making the css file invalid.
Changing the encoding to UTF-8 got it working. Maybe this is a bug, or perhaps at least mention it in the docs; as this issue could easily trip people up? thanks.
I can’t get the css working.
I checked in notepad++ what the encoding is UTF-8.
Still can’t get it working.
How did you troubleshoot the problem with your CSS?
Maybe this can help others…
You can open the developer console.
All the css errors can be drilled in from there
