Is there a way to navigate note-to-note inside a notebook or search results?
Joplin 3.3.12 (prod, linux)
I've looked through the menu's and the plugins but don't see this.
If I'm in a note in a notebook, and want to move to the next note in the current Notebook, or in the search results list, is there any keystroke or menu that will let me do that (other than picking the next note from the sidebar menu, which is distracting on the desktop and tedious on the App) ?
Obviously I could create links in all the notes, but that takes time and has to be patched if a new note is inserted.
The use case is if you're studying some notes on a topic, you would like to hop to the next note without interruption.
Workarounds I've considered include using the notes overview plugin to create a flattened view of the Notebook. The problem with this is that you're looking at a copy of the text, so if you want to add notes to the text as you read you can't (unless you hop back to the original text, change it, and then update the overview).
Thank you!
ctrl+shift+l should get your focus back to the Note list
Then down arrow for the next note
Tab (I think) to get back to the note area
