Is there a list for Android compatible Plugins?
I know how to search for Plugins within the App, but I would like to see a list of all Android compatible plugins. Thanks
One option to discover this: Go to Plug-ins under the Joplin app settings on your Android device, and simply enter a space in the search-for-plugins box. It will return all plug-ins, listed in an an order that shows the compatible plug-ins first, followed by the incompatible plug-ins, and labelled as such.
HTH
thats perfect, thank you
  1. Works that way also in Joplins iOS app for apple devices.
  2. I would recommend to make this a standard behaviour. It would be convenient for every user to see the list of plugins immediately when he/she opens the plugin settings section.
I would also like to concur with the recommendation. Otherwise it's simply impossible to know (without previous knowledge or experimenting) that pressing "space" in particular is going to show the full list of plugins.
Alternatively, if listing all available plugins by default is undersireble, maybe consider adding a note about this "space" method under the plugin search box?
