Is there a calendar plugin for Joplin?
So, I see a calendar in the screenshot here for the plugin macOS theme, but I don't know how that function works, how can I pull out a calendar from the plug in, or is there a calendar plug in for Joplin?
Thanks...
I'm not sure where the plugin from the screenshot comes from, but if you type in "calendar" in the plugin section it finds two...
I think it might be the agenda one.
Ahh, ok, I did install it before, I couldn't figure out how to use it, and I just installed it again, I still don't know how to use it, it shows nothing in there, at least the Kanban plugin will show all the tasks... But in Agenda, nothing...And I can't add tasks within the plugin window... So it's very confusing for me...But thanks, it does say "calendar" in the description...
So, if you click on the plugin title, it will take you somewhere that the plugin author has more instructions. Unfortunately this is irregular. In this case it takes you to the post on this forum where the plugin was announce. But there is not much info. If you wanted to, that would be a good place to ask questions.
But there is a link to the repository on gitlab. Again, this is kind of confusing because you have to scroll down to get to the readme section. Once you are there you can see more detailed instructions.
