I discovered a work-around trick to bypass a bug that prevents you from assigning a shortcut key
Hi, I just found a trick that lets you bypass a bug that prevents you from assigning a shortcut key by luck.
Unlike the author of the bug report linked above, I use Ubuntu 24.04, but I experience the same bug.
The version of Joplin-Desktop is 3.6.15
The way I assigned the key goes like this:
  1. At Keyboard Shortcuts screen, assign the key combination you want to the desired function, after pressing Restore button when the triangular icon for the warning that reads an unrelated shortcut key combination is used by some other functions is shown around the right edge. (You won't be able to assign the desired key when the warning is shown, without pressing the Restore button)
  2. Press Export button and save the file.
  3. Restart joplin-desktop, and go back to Keyboard Shortcuts screen again.
  4. Press Import button, and import the file you have just saved, but you will find out your desired shortcut key is still not yet assigned, and that the order of the shortcut key table is different.
  5. Assign the desired shortcut key again, and now it will get assigned to the function without a problem.
I hope it would help @gsr, and some other joplin-desktop users.
Best Wishes.
By the way, I find it very useful to have Alt+→assigned to Forward, and Alt+← to Back
