Either I do something seriously stupid or there is serious issue with Joplin UI. For more than one hour I am unable to sync Joplin between my desktop app and mobile app using Dropbox. On each device I ask for authorization code for Dropbox and I successfully "pair" the app with Dropbox. But still, each app uses its own text files which are not in sync. I even tried to reinstall the apps and use one same auth code for all devices - which did not work because Joplin allow the auth code to be used only once. Thanks for the help.
