How to display links icon in WYSIWYG editor?
Hello all,
is there a way to display the links icon on the WYSIWYG editor?
Actually they are displayed only on the MD editor.
TIA
tony
Hi, I got the same question. For now, I'm using custom css as described in Prefix internal links in richtext editor.
Hi Marph,
I copied your code in the "CSS for joplin-wide app" style but nothing changes.
Links remain the same in the rich editor. I just restarted joplin to be sure, but nothing changed.
Perhaps I need to wrap every link with your code? If so, it's really time consuming... and not end-user friendly.
Or am I missing something?
Thanks, anyway.
Tony
Not sure what "CSS for joplin-wide app" means. Here is what worked for me:
  1. Navigate to Help -> Open profile directory
  2. Paste the CSS into userstyle.css and save it
  3. Restart Joplin
Then you should see a black Joplin icon in front of internal links. It's not very pretty, but sufficient for me.
