How to apply strikethrough to text quickly?
Joplin 1.6.8 (prod, linux)
Sync Version: 2
Profile Version: 34
Revision: fc7bd41 (master)
Hi there,
From what I can see, you can apply strikethrough to text with the <s> </s> html tag.
Is there a way to apply this from a keyboard shortcut (or even from the command palette)?
For reference, the keyboard shortcut ctrl + B will apply the "textBold" feature to wrap text with ** **.
Thanks!
barydos
Not a shortcut, but surrounding the text by two tildes before and two tildes after is a common Markdown convention. This appears to render correctly in the Android app, and it's easier than typing all those HTML tags.
