Highlight inside blockquote
I can, say, highlight text within blockquote:
> This is a blockquote and ==this part is highlighted.==
But highlighting does not work inside, say,
<blockquote>
</blockquote>
What is the way to make it work?
It is because you can use either Markdown or HTML, not a mix of both as in your second example.
Your options would be:
or
<blockquote>
	This is a blockquote and <mark>this part is highlighted.</mark>
</blockquote>
Somebdy may correct my but to my knowledge, it can't be simply done with any flavor of markdown. But a little tinkering with html might help, resulting in something like this:
<pre> This is a blockquote and ==<b>this part is highlighted.</b>== </pre>
This will look like this:
If this suffices, just reorder this a bit (add a new line after the opening pre). :slight_smile:
My statement above was not quite right, you can use HTML in Markdown, but not Markdown in HTML.
So
will also work in Joplin.
This was not the OP's specific question but has just been added for correctness.
