Help with Installation problems on WSL Terminal
Hi everyone, i'm trying to install the version 1.6.3 on WSL terminal following the website guide and i'm getting some errors, I don't know what to google, I was not able to find a post with the problesms. Here's the log of npm:
make: Entering directory '/home/bzaragoza/.joplin-bin/lib/node_modules/joplin/node_modules/sqlite3/build'
CC(target) Release/obj.target/nothing/../node-addon-api/nothing.o
make: cc: Command not found
make: *** [../node-addon-api/nothing.target.mk:107: Release/obj.target/nothing/../node-addon-api/nothing.o] Error 127
make: Leaving directory '/home/bzaragoza/.joplin-bin/lib/node_modules/joplin/node_modules/sqlite3/build'
gyp ERR! build error
gyp ERR! stack Error: make failed with exit code: 2
gyp ERR! stack at ChildProcess.onExit (/home/bzaragoza/.nvm/versions/node/v14.15.4/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
gyp ERR! stack at ChildProcess.emit (events.js:315:20)
gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:277:12)
gyp ERR! System Linux 4.4.0-18362-Microsoft
gyp ERR! command "/home/bzaragoza/.nvm/versions/node/v14.15.4/bin/node" "/home/bzaragoza/.nvm/versions/node/v14.15.4/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/home/bzaragoza/.joplin-bin/lib/node_modules/joplin/node_modules/sqlite3/lib/binding/napi-v6-linux-x64/node_sqlite3.node" "--module_name=node_sqlite3" "--module_path=/home/bzaragoza/.joplin-bin/lib/node_modules/joplin/node_modules/sqlite3/lib/binding/napi-v6-linux-x64" "--napi_version=7" "--node_abi_napi=napi" "--napi_build_version=6" "--node_napi_label=napi-v6"
gyp ERR! cwd /home/bzaragoza/.joplin-bin/lib/node_modules/joplin/node_modules/sqlite3
gyp ERR! node -v v14.15.4
gyp ERR! node-gyp -v v5.1.0
gyp ERR! not ok
node-pre-gyp ERR! build error
node-pre-gyp ERR! stack Error: Failed to execute '/home/bzaragoza/.nvm/versions/node/v14.15.4/bin/node /home/bzaragoza/.nvm/versions/node/v14.15.4/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/home/bzaragoza/.joplin-bin/lib/node_modules/joplin/node_modules/sqlite3/lib/binding/napi-v6-linux-x64/node_sqlite3.node --module_name=node_sqlite3 --module_path=/home/bzaragoza/.joplin-bin/lib/node_modules/joplin/node_modules/sqlite3/lib/binding/napi-v6-linux-x64 --napi_version=7 --node_abi_napi=napi --napi_build_version=6 --node_napi_label=napi-v6' (1)
node-pre-gyp ERR! stack at ChildProcess. (/home/bzaragoza/.joplin-bin/lib/node_modules/joplin/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
node-pre-gyp ERR! stack at ChildProcess.emit (events.js:315:20)
node-pre-gyp ERR! stack at maybeClose (internal/child_process.js:1048:16)
node-pre-gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:288:5)
node-pre-gyp ERR! System Linux 4.4.0-18362-Microsoft
node-pre-gyp ERR! command "/home/bzaragoza/.nvm/versions/node/v14.15.4/bin/node" "/home/bzaragoza/.joplin-bin/lib/node_modules/joplin/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
node-pre-gyp ERR! cwd /home/bzaragoza/.joplin-bin/lib/node_modules/joplin/node_modules/sqlite3
node-pre-gyp ERR! node -v v14.15.4
node-pre-gyp ERR! node-pre-gyp -v v0.11.0
node-pre-gyp ERR! not ok
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.1 (node_modules/joplin/node_modules/chokidar/node_modules/fsevents):
npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.1: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! sqlite3@5.0.1 install: node-pre-gyp install --fallback-to-build
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the sqlite3@5.0.1 install script.
npm ERR! /home/bzaragoza/.npm/_logs/2021-01-18T06_04_20_555Z-debug.log
Hope, it's enough to get help. Thanks.
having the same issue... I either can't install the cli or can't open it... and i've tried on my ubuntu, on my mac, and now my WSL!!!
same for me :thinking:
