HELP needed: Sync Target upgrade error
This morning on starting my favorite companion on my work laptop, I got a message that the sync target needs to be upgraded. However, I don't recall having updated the joplin app. It looks like syncing from android phone still works.
Laptop: win 11 (just upgraded from win 10),
Joplin info:
Joplin 2.9.17 (prod, win32)
Client ID: XXX
Profile Version: 41
Revision: a84a8e7
Please help, as I really got to rely on Joplin.
Maarten
Error
The sync target could not be upgraded due to an error. For support, please copy the complete content of this page and paste it in the forum: https://discourse.joplinapp.org/
The full error was:
Could not upgrade from version 1 to version 2: PUT info.json: "Joplin/info.json" is locked (Exception OCA\DAV\Connector\Sabre\Exception\FileLocked) (423): <?xml version="1.0" encoding="utf-8"?> <d:error xmlns:d="DAV:" xmlns:s="sabre/dav"> <s:exception>OCA\DAV\Connector\Sabre\Exception\FileLocked</s:exception> <s:message>"Joplin/info.json" is locked</s:message> </d:error>
Error: Could not upgrade from version 1 to version 2: PUT info.json: "Joplin/info.json" is locked (Exception OCA\DAV\Connector\Sabre\Exception\FileLocked) (423): <?xml version="1.0" encoding="utf-8"?>
</d:error>
at newError (C:\Users\BonnemaGM\AppData\Local\Programs\Joplin\resources\app.asar\node_modules\@joplin\lib\WebDavApi.js:414:11)
at WebDavApi.exec (C:\Users\BonnemaGM\AppData\Local\Programs\Joplin\resources\app.asar\node_modules\@joplin\lib\WebDavApi.js:441:11)
at process.processTicksAndRejections (node:internal/process/task_queues:96:5)
at async FileApiDriverWebDav.put (C:\Users\BonnemaGM\AppData\Local\Programs\Joplin\resources\app.asar\node_modules\@joplin\lib\file-api-driver-webdav.js:201:10)
Additional info: on my old linux box, with the same version of joplin running, things look fine.
Some more info: it works on the linux box, and the upgrade took place successfully on that one. I noticed that in the webdav folder there were two files in the locks folder. After closing all apps, one file remained. I deleted that one.
Still, syncing fine on the linux box. No upgrade possible on the win11 box with the same error page shown.
Also, the Android app (v2.10.8) now raises error about not being able to upgrade due to file .sync/version.txt being locked
Any help much appreciated!
This is a bug in nextcloud, if you search for filelocked you'll find many threads about this
