Help link out of date
Joplin 3.3.13 (prod, win32)
Nextcloud
Under Welcome > Synchronising your notes > Setting up Nextcloud synchronisation it says "...go to your Nextcloud page, click on Settings in the bottom left corner of the page and copy the URL". This appears to be wrong, there's no such page or link (at least not in Nextcloud 10, 31.0.7). I eventually found it in the dashboard under Files > Files settings > WebDAV.
Also, this does NOT appear to be the recommended way to sync to Nextcloud. Nextcloud advises using their own sync system rather than third party WebDAV clients because it's more robust and logs accesses etc. Joplin seems to synchronise quite happily that way simply by using a local copy of the notebook in the Nextcloud folder, which is simpler to set up (no new authentication needed). The synchronise button in the bottom left still works as expected, even (especially) if offline. Can you confirm this?
If you're on Windows and your target is next cloud their client wants to synchronize local folders to the cloud so you would need to set up Joplin to use local file system and then let the next Cloud client synchronize it to the server.
This may be the way that next Cloud recommends people do things but it may not work that way.
Is there any specific problem that you have run into that is preventing you from using next cloud? Is there a specific question that you have about something other than the documentation?
