Graph not working suddently
Joplin 3.3.13 (prod, linux)
Device: linux, 13th Gen Intel(R) Core(TM) i7-13620H
Client ID: 3e0cb3f00e334454bf784cb1dfd6f55a
Keychain Supported: No
Alternative instance ID: -
Revision: 144ed59
Backup: 1.4.3
Bidirectional Links: 0.2.1
Freehand Drawing: 3.0.1
Graph: 1.1.0
Inline Tag Navigator: 2.5.0
Inline tags: 1.3.0
Templates: 2.4.0
Not sure why, but the graph app is not showing anyting anymore....
I looked at the dev info, and the only 2 things that show are :
Unrecognized feature : /tmp/.mount_JoplinCe….development.js:798 Unrecognized feature: 'clipboard-write=(self)'. setValueForProperty @ /tmp/.mount_JoplinCe….development.js:798
And this one, which seams related to Graph
Canvas2D: Multiple readback operations using getImageData are faster with the willReadFrequently attribute set to true. See: https://html.spec.whatwg.org/multipage/canvas.html#concept-canvas-will-read-frequently
And there are multiple lines of :
requestAnimationFrame
animate @ force-graph.module.js:1738
I tried to deinstal et reinstal, but that doesn't change anything.
Any ideas ?
EDIT : opened github issue : Graph suddently not showing (black page) : Canvas2D issue ? · Issue #29 · agerardin/joplin-plugin-knowledge-graph · GitHub
Try raising an issue in the GitHub repository for the plugin here:
