FIXED - Bulleted, numbered and checkboxed lists : strange behaviour (RTE) - BUG
Joplin 3.3.3 (prod, win32)
Client ID: 0cfa1760cd8342dd8375a8fea00f3d9b
Keychain Supported: No
Alternative instance ID: -
Revision: 23254e6
Rich Text Editor
I start with 3 lines :
I click on the first line and use, for example, the bulleted lists button.
I don't move the insertion point.
I click this time in the numbered list. It doesn't apply to the first line but to the second line...
I click on the checkboxed button. It apply automatically to the third line....
Not logical for me : things should have apply to the first line only....
Ok. This time I select the 3 previous lines
I click on the numbered list button:
All the lines get number one !!!
Not logical : why not 1,2, and 3 ?
And so on...
Is it normal ?
I'm getting similar odd behavior on indenting and automated renumber of ordered lists. It is particularly noticeable at indent level 3. Rendered output is correct regardless of the raw text.
2025-04-05_15-58-37
You can see that item "5" doesn't change.
Joplin 3.2.13 (prod, win32)
Client ID: 0b9eac1ab38b4d019ba53fed6546b685
Revision: a898e17
Backup: 1.4.2
Freehand Drawing: 2.14.0
Outline: 1.5.13
Looks like : Numbered Lists Reordering
