As the title says, whenever I do a clean check out of dev and run npm i, I end up with a bunch of changed files that aren't ignored by git.
Not a huge issue but a bit annoying as I can't do git add . because of these changes.
Wondering if anyone else have this issue.
The changed files are:
modified: .eslintignore
modified: .gitignore
modified: package-lock.json
modified: packages/app-clipper/popup/package-lock.json
modified: packages/app-desktop/gui/NoteEditor/NoteBody/TinyMCE/supportedLocales.js
modified: packages/app-desktop/gui/note-viewer/lib.js
modified: packages/app-mobile/package-lock.json
modified: packages/lib/package-lock.json
modified: packages/renderer/package-lock.json
All files except package-lock.json have only line ending changes (btw I'm on Linux and have autocrlf enabled).
This is the beginning of the diff for the root package-lock (the whole diff is pretty long):
"name": "root",
+ "lockfileVersion": 2,
"requires": true,
- "lockfileVersion": 1,
+ "packages": {
+ "name": "root",
+ "hasInstallScript": true,
+ "license": "MIT",
+ "devDependencies": {
+ "@typescript-eslint/eslint-plugin": "^4.6.0",
+ "@typescript-eslint/parser": "^4.6.0",
