macOS
Joplin for Desktop
Copyright © 2016-2024 Laurent Cozic
Joplin 3.2.3 (prod, darwin)
Client ID: 4bb9eabc3b1042c893b0dfcd11781134
Revision: 1993d30
Backup: 1.4.2
Conflict Resolution: 1.2.3
File system
Rich Text Editor
I am trying to get consistent results when opening a text note from within the Rich Editor in an external editor (in my case Drafts, a very convenient Appstore app). Not a problem to get Joplin to start the Drafts app with the correct general options dialog field / path, but every time I try, Drafts opens and reports "import failed".
Here are the different "path" inputs I have used so far:
/Applications/Drafts.app/Contents/MacOS/Drafts
open -a ~/Applications/Drafts.app/Contents/MacOS/Drafts
Could anybody give me advice what's going wrong ?
Existing threads on similar problems all seem relatively old and address different problems.
Thanks
