Export note without folder structure
I am trying to export a single note in MD format from export menu.
Currently Joplin exports nodes with its notebook path
Is it possible to export without full folder structure ?
Any one?
Export one note only: Right click on note and go to "Export" 🡒 "MD - Markdown".
Is this what you meant?
Thanks @Angel_Crawford_ftw for reply yes this is what I am trying but it exports full note hierarchy as folders
I just want .md file in target folder not note hierarchy .
Not sure what your original motivation was to give you a good solution. But anyway, you can programmatically reduce the exported files to a directory
