Hello, when I run npm install from the root directory I get a bunch of errors on my terminal, am using Mac Os Catalina. Please I'll appreciate getting help solving this.
Versions of Node and Npm currently installed
node --version: v14.16.0
npm --version: 6.14.11
Error log
npm WARN read-shrinkwrap This version of npm is compatible with lockfileVersion@1, but package-lock.json was generated for lockfileVersion@2. I'll try to do my best with it!
> root@ postinstall /Users/jay/joplin
> npm run bootstrap --no-ci && npm run build
> root@ bootstrap /Users/jay/joplin
> lerna bootstrap --no-ci
lerna notice cli v3.22.1
lerna info versioning independent
lerna info Bootstrapping 15 packages
lerna info Installing external dependencies
lerna ERR! npm install exited 1 in 'joplin'
lerna ERR! npm install stdout:
> fsevents@1.2.11 install /Users/jay/joplin/packages/app-cli/node_modules/fsevents
> node-gyp rebuild
> keytar@7.0.0 install /Users/jay/joplin/packages/app-cli/node_modules/keytar
> prebuild-install || node-gyp rebuild
lerna ERR! npm install stderr:
No receipt for 'com.apple.pkg.CLTools_Executables' found at '/'.
No receipt for 'com.apple.pkg.DeveloperToolsCLILeo' found at '/'.
No receipt for 'com.apple.pkg.DeveloperToolsCLI' found at '/'.
gyp: No Xcode or CLT version detected!
gyp ERR! configure error
gyp ERR! stack Error: `gyp` failed with exit code: 1
gyp ERR! stack at ChildProcess.onCpExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)
gyp ERR! stack at ChildProcess.emit (events.js:315:20)
gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:277:12)
gyp ERR! System Darwin 19.6.0
gyp ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
gyp ERR! cwd /Users/jay/joplin/packages/app-cli/node_modules/fsevents
gyp ERR! node -v v14.16.0
gyp ERR! node-gyp -v v5.1.0
gyp ERR! not ok
prebuild-install WARN install No prebuilt binaries found (target=14.16.0 runtime=node arch=x64 libc= platform=darwin)
gyp ERR! cwd /Users/jay/joplin/packages/app-cli/node_modules/keytar
gyp ERR! not ok
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.11 (node_modules/fsevents):
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.11 install: `node-gyp rebuild`
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! keytar@7.0.0 install: `prebuild-install || node-gyp rebuild`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the keytar@7.0.0 install script.
npm ERR! /Users/jay/.npm/_logs/2021-03-16T00_27_52_163Z-debug.log
lerna WARN complete Waiting for 2 child processes to exit. CTRL-C to exit immediately.
npm ERR! errno 1
npm ERR! root@ bootstrap: `lerna bootstrap --no-ci`
npm ERR!
npm ERR! Failed at the root@ bootstrap script.
npm ERR! /Users/jay/.npm/_logs/2021-03-16T00_27_52_288Z-debug.log
npm ERR! errno 1
npm ERR! root@ postinstall: `npm run bootstrap --no-ci && npm run build`
npm ERR!
npm ERR! Failed at the root@ postinstall script.
npm ERR! /Users/jay/.npm/_logs/2021-03-16T00_27_52_413Z-debug.log
~/joplin ```
It looks like you're missing some native build dependencies. I have no experience with macOS so I can't say for sure what the issue is (some others on the forum will know better).
First of all, did you install the required dependencies?
If so, do you have Xcode installed? Your error above (gyp: No Xcode or CLT version detected!) suggests it isn't.
Yes, I installed Cocoapods, and i have Xcode installed as well
From your hint, I did a reset on the command-line tools using sudo xcode-select --reset, this fixed the initial errors, but now running npm install from the root directory returns a new set of errors
Error log
lerna info Symlinking packages and binaries
lerna info lifecycle @joplin/app-clipper@1.0.8~postinstall: @joplin/app-clipper@1.0.8
lerna info lifecycle @joplin/app-desktop@1.8.0~postinstall: @joplin/app-desktop@1.8.0
lerna info lifecycle @joplin/app-mobile@0.8.9~postinstall: @joplin/app-mobile@0.8.9
> @joplin/app-clipper@1.0.8 postinstall /Users/jay/joplin/packages/app-clipper
> cd popup && npm install
> fsevents@1.2.11 install /Users/jay/joplin/packages/app-clipper/popup/node_modules/jest-haste-map/node_modules/fsevents
> node-gyp rebuild
SOLINK_MODULE(target) Release/.node
CXX(target) Release/obj.target/fse/fsevents.o
In file included from ../fsevents.cc:6:
In file included from ../../../../nan/nan.h:2884:
../../../../nan/nan_typedarray_contents.h:34:43: warning: 'GetContents' is deprecated: Use GetBackingStore. See http://crbug.com/v8/9908.
[-Wdeprecated-declarations]
data = static_cast<char*>(buffer->GetContents().Data()) + byte_offset;
/Users/jay/Library/Caches/node-gyp/14.16.0/include/node/v8.h:5272:3: note: 'GetContents' has been explicitly marked deprecated here
V8_DEPRECATE_SOON("Use GetBackingStore. See http://crbug.com/v8/9908.")
/Users/jay/Library/Caches/node-gyp/14.16.0/include/node/v8config.h:402:39: note: expanded from macro 'V8_DEPRECATE_SOON'
# define V8_DEPRECATE_SOON(message) [[deprecated(message)]]
1 warning generated.
SOLINK_MODULE(target) Release/fse.node
> fsevents@1.2.12 install /Users/jay/joplin/packages/app-clipper/popup/node_modules/react-scripts/node_modules/chokidar/node_modules/fsevents
> node-gyp rebuild
In file included from ../../../../../../nan/nan.h:2884:
../../../../../../nan/nan_typedarray_contents.h:34:43: warning: 'GetContents' is deprecated: Use GetBackingStore. See
http://crbug.com/v8/9908. [-Wdeprecated-declarations]
> fsevents@1.2.11 install /Users/jay/joplin/packages/app-clipper/popup/node_modules/watchpack/node_modules/fsevents
> node-gyp rebuild
> fsevents@1.2.11 install /Users/jay/joplin/packages/app-clipper/popup/node_modules/webpack-dev-server/node_modules/fsevents
> node-gyp rebuild
> core-js@2.6.11 postinstall /Users/jay/joplin/packages/app-clipper/popup/node_modules/babel-runtime/node_modules/core-js
> node -e "try{require('./postinstall')}catch(e){}"
Thank you for using core-js ( https://github.com/zloirock/core-js ) for polyfilling JavaScript standard library!
The project needs your help! Please consider supporting of core-js on Open Collective or Patreon:
> https://opencollective.com/core-js
> https://www.patreon.com/zloirock
Also, the author of core-js ( https://github.com/zloirock ) is looking for a good job -)
> core-js@3.6.4 postinstall /Users/jay/joplin/packages/app-clipper/popup/node_modules/core-js
> core-js-pure@3.6.5 postinstall /Users/jay/joplin/packages/app-clipper/popup/node_modules/core-js-pure
> joplin-webclipper-popup@0.1.0 postinstall /Users/jay/joplin/packages/app-clipper/popup
> node postinstall.js && npm run build
> joplin-webclipper-popup@0.1.0 build /Users/jay/joplin/packages/app-clipper/popup
> node scripts/build.js SKIP_PREFLIGHT_CHECK
Creating an optimized production build...
Browserslist: caniuse-lite is outdated. Please run the following command: `npm update`
Compiled successfully.
File sizes after gzip:
48.12 KB build/static/js/2.chunk.js
7.52 KB build/static/js/main.chunk.js
775 B build/static/js/runtime-main.js
746 B build/static/css/main.chunk.css
The project was built assuming it is hosted at ./.
You can control this with the homepage field in your package.json.
The build folder is ready to be deployed.
Find out more about deployment here:
bit.ly/CRA-deploy
npm WARN The package fs-extra is included as both a dev and production dependency.
added 2127 packages from 889 contributors and audited 2131 packages in 137.472s
60 packages are looking for funding
run `npm fund` for details
found 8837 vulnerabilities (8778 low, 37 moderate, 22 high)
run `npm audit fix` to fix them, or `npm audit` for details
> @joplin/app-desktop@1.8.0 postinstall /Users/jay/joplin/packages/app-desktop
> npm run build
> @joplin/app-desktop@1.8.0 build /Users/jay/joplin/packages/app-desktop
> gulp build
/Users/jay/joplin
[03:31:52] Using gulpfile ~/joplin/packages/app-desktop/gulpfile.js
[03:31:52] Starting 'build'...
[03:31:52] Starting 'compileScripts'...
[03:31:52] Starting 'compilePackageInfo'...
[03:31:52] Starting 'copyPluginAssets'...
[03:31:52] Starting 'copyTinyMceLangs'...
[03:31:52] Starting 'updateIgnoredTypeScriptBuild'...
Compiling /Users/jay/joplin/packages/app-desktop/tools/../gui/ClipperConfigScreen.jsx...
Error: spawnSync /Users/jay/joplin/packages/app-desktop/tools/../node_modules/.bin/babel ENOENT
at Object.spawnSync (internal/child_process.js:1067:20)
at spawnSync (child_process.js:602:24)
at /Users/jay/joplin/packages/app-desktop/tools/compileScripts.js:31:19
at Array.forEach (<anonymous>)
at convertJsx (/Users/jay/joplin/packages/app-desktop/tools/compileScripts.js:17:23)
at module.exports (/Users/jay/joplin/packages/app-desktop/tools/compileScripts.js:45:2)
at compileScripts (/Users/jay/joplin/packages/app-desktop/node_modules/undertaker/lib/set-task.js:13:15)
at bound (domain.js:413:15)
at runBound (domain.js:424:12)
at asyncRunner (/Users/jay/joplin/packages/app-desktop/node_modules/async-done/index.js:55:18) {
errno: -2,
code: 'ENOENT',
syscall: 'spawnSync /Users/jay/joplin/packages/app-desktop/tools/../node_modules/.bin/babel',
path: '/Users/jay/joplin/packages/app-desktop/tools/../node_modules/.bin/babel',
spawnargs: [
'--presets',
'react',
'--out-file',
'/Users/jay/joplin/packages/app-desktop/tools/../gui/ClipperConfigScreen.min.js',
'/Users/jay/joplin/packages/app-desktop/tools/../gui/ClipperConfigScreen.jsx'
[03:31:52] The following tasks did not complete: build, compileScripts, compilePackageInfo, copyPluginAssets, copyTinyMceLangs, updateIgnoredTypeScriptBuild
[03:31:52] Did you forget to signal async completion?
npm ERR! errno 1
npm ERR! @joplin/app-desktop@1.8.0 build: `gulp build`
npm ERR!
npm ERR! Failed at the @joplin/app-desktop@1.8.0 build script.
npm ERR! /Users/jay/.npm/_logs/2021-03-16T02_31_52_998Z-debug.log
lerna info lifecycle @joplin/app-desktop@1.8.0~postinstall: Failed to exec postinstall script
> @joplin/app-mobile@0.8.9 postinstall /Users/jay/joplin/packages/app-mobile
> jetify && npm run build
sh: jetify: command not found
npm ERR! errno 1
npm ERR!
npm ERR! /Users/jay/.npm/_logs/2021-03-16T02_31_53_122Z-debug.log
npm ERR! errno 1
npm ERR!
npm ERR! /Users/jay/.npm/_logs/2021-03-16T02_31_53_287Z-debug.log
Now it says this file does not exist
You can manually check if that is correct. What you can do now though is try deleting
and
/Users/jay/joplin/packages/app-desktop/package-lock.json
and then run npm install from /Users/jay/joplin/ again
