lerna ERR! npm install exited 1 in '@joplin/renderer'
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! root@ bootstrap: `lerna bootstrap --force-local --no-ci`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the root@ bootstrap script.
npm ERR! /Users/shabana/.npm/_logs/2021-11-06T18_04_27_282Z-debug.log
npm ERR! errno 1
npm ERR! root@ postinstall: `npm run bootstrap --no-ci && npm run build`
npm ERR!
npm ERR! Failed at the root@ postinstall script.
node version: v14.18.1
npm version: 6.14.15
OS: macOS
command: npm install from root directory
