Entry problems (solved)
Hello everyone. Everything was fine with Joplin, but for some time I have a seizure problem. The cursor is never at the right place in the text. When I cut a sentence where the cursor is, the sentence is cut one or two words before or one or words after. It’s very strange and I do not understand the problem. I am on OSX. If someone has an idea? Thank you so much.
Problem solved. The problem came from the font that I had changed in the options. This font was not monospace. Joplin works only with monospace font.
