Electron Helper wants to connect to ingest.sentry.io
When I run Joplin from the source tree via npm run start and upon closing Joplin, Electron helper wants to connect to o4506576757522432.ingest.sentry.io.
I seriously doubt that Joplin is doing this on purpose, but I suspect that Electron added telemetry when being run in dev mode.
I just wanted to put it out there.
That must be the Sentry crash handler I've added. It doesn't auto-upload crash logs by default, but looks like the initialisation itself means it's connecting to some server. I will disable this too, thanks for the information.
I recommend that you disable Sentry and use your own hosted crash log stuff in if you want to call Joplin as a private note solution. Please see the post below for more details about what Sentry's real intentions are
It does not matter if they posted a correction blog, the intention is there and eventually they will get there.
Sentry will use user data to train AI models without user consent (sentry.io)
https://news.ycombinator.com/item?id=38909553
Sentry new TOS to use data to train AI with no opt-out (sentry.io)
https://news.ycombinator.com/item?id=38877059
I already implemented my own stuff which works offline.
