Downloads for Installation/Update Repeatedly Failing, Incomplete
Joplin 3.2.11 (prod, win32)
Client ID: 6c256236d1294b2d80b2b8306232eebb
Revision: 2fba101
Backup: 1.4.2
Freehand Drawing: 2.14.0
Quick HTML tags: 0.2.0
OneDrive
For many months now, each time I accept a prompt to download a Joplin update, when Firefox (latest) indicates completion, I end up with a large joplinxxxx.part file, some hundreds of kbytes and a, say, Joplin-Setup-3.2.11.exe file of ZERO bytes.
Inadvertently running the exe causes a 'This program can't run on this PC' pop-up, of course. Renaming the zero-byte .part file to .exe and running it fails, because, I have inferred, it is incomplete, too small.
I have just downloaded Joplin itself from the home page, renaming before saving as joplin-setup-etc-2.exe. When it completed I had Joplin-Setup-3.2.11.exe in full size plus Joplin-Setup-3.2.11-2.exe as a zero-byte file. The xxx.part file remained unchanged.
This is clearly not a successful download arrangement.
Only Windows 10's Defender is running as a file-checker. Firefox's uBlock Origin, BitWarden; nothing much else.
As I say, over many months this download faulting has been occurring.
Anyone else?
Let's try different environment for the download
  • different browser
  • different network
  • temporary disable file checking from Defender during the download
Does the same happen when you download portable version btw?
Ha! Mea culpa!
I had a 'light-bulb' moment today: it turns out that my 'nothing much else' was the cause of Joplin-Setup .part download failures.
I have Syncredible set up to synchronise two download folders between two computers, and, sure enough, Synchredible was detecting the arrival of the .part file and its zero-length .exe companion.
Copying a live downloading partial file really screwed things up.
By adding a *.part item in Syncredible's Exclusions list, things behaved well. The zero-length temporary .exe present during download was still copied to the sync computer, but that's a factor I can live with. It'll be detected in the next monitoring-activation event.
SO, this thread can be deleted or just marked as SOLVED, but it's a possible alert for anyone running a file and folder monitoring program - RealTime Sync, File & Folder Watch, etc.
