Distance between lines are to high
in windows version that are synced note with android when i press enter distance between line go high very high
Hey there, most likely you're using rich text editor that registers enter as next paragraph - hence an extra blank line between the lines
It's part of markdown standard which Joplin follows
Shift+enter would insert no such blank line
Hope this helps
HI
No have way to disable this bad standard ?
maybe this is helpful: before post.
op said this is possible to modify rendering behaviour of rich markdown editor so it do not render as two new line (\n).
p.s., but I think it is impossible to change markdown standard, because markdown standard is widely used every where, and joplin jiust another markdown note software.
