Hello all,
sometimes I need to display images as links instead of the images themselves.
So, I would import the image and then I would use his data to create the link to it.
But I haven't found a solution that would work across all devices. In fact, I can get the image link in windows, but how can I get the link that is valid for mobile too?
I know the resource ID. But then?
Thanks you in advance for any help.
tony
When you import an image it will appear in markdown as something like
and display as a picture.
If you remove the exclamation mark it appears as a link.
[picture.png](:/29fec3f161c44ffda9870284547bfb74)
