Command Palette: Focus issues
I like the command palette (ctrl-shift-p) very much but unfortunately the note looses it's focus in most of the times I use it.
For example: I press ctrl-shift-p and the command palette pops up. Then I start writing "check" and hit enter. Then a Checkbox item is created and the "list item" is marked. It would be great if I could immediately start editing this item but the note looses the focus somehow so that i have to click in the note again to continue writing.
This happens in the markdown editor. In the WYSIWYG editor, the checkbox isn't even created.
Version/OS
Joplin 1.7.11, Windows 10
Hi, I'm not near my system right now so I can't test, but if you can reproduce it (which from the desc. I think you can), you should open an issue on the issue tracker
thanks. I've opened a bug issue.
