Combine tags
When you use tags a lot, you often have to search for notes by combining several of them. There are at least 1 evolution that would be very usefulK To be able to select (Ctrl + click for example) more than one tags in the left panel which would result in copying them into the search field in the form tag: "tag1" tag: "tag2"
Yes It's a interesting idea. I had a similar in November.
