Is there a way to make code block syntax highlighting more convenient for a bunch of code blocks of the same syntax?
For example to make groups of code blocks in a document follow the same syntax highlighting style without having to explicitly define it on every code block?
My suggestion would be this to be done with a flag to indicate which group needs the same syntax highlighting. (I do question if this is possible without impacting much of the document rendering.)
Here is a visual example of a group -grp
flag:
code blocks below this code block flag will be all powershell syntax highlighting
```powershell-grp
dir
dir *.zip
code blocks below this code block flag will be all bash syntax highlighting
```bash-grp
ls
ls -a
