How can I prevent code highlights in code blocks
Cosmo: 7 March 2022
Joplin version 2.7.13 linux, kubuntu 5.13.0-30 generic
I would like to disable code highlighting for markdown blocks delimited by triple backticks
I believe the solution might be to modify either userstyle or userchrome css files.
Can anyone assist please?
To disable just for specific blocks you can mark the block as plaintext
```plaintext
No highlighting here!
Otherwise place the following in your userstyle.css
pre.hljs * {
	color: inherit;
