Code block hides anything between <>
Joplin 3.4.12 (prod, win32)
Device: win32, AMD Ryzen 7 5800H with Radeon Graphics
Client ID: 0eba133bf40e422fa62146c80df1b9b3
Profile Version: 48
Alternative instance ID: -
Revision: e9a9f68
AlertsPerfect: 1.0.1
Backup: 1.4.3
CodePerfect: 1.0.2
Csv Import: 1.0.1
Editor Themes: 1.0.2
Extra Markdown editor settings: 1.11.0
Google Fonts Plugin: 1.0.0
Headings 4 to 6: 1.0.1
Hotstrings & Hotkeys: 1.0.1
Insert Date: 1.0.1
Math Mode: 0.8.3
Note Statistics: 1.0.4
Search & Replace: 2.2.0
Table Formatter Plugin: 1.2.1
Templates: 3.0.0
Text Colorize: 1.2.5
OneDrive
I'm trying to write a bnf code block, but the angle brackets and any text between do not render. I tried enabling/disabling Tools > Options > Markdown editor: Render markup in editor. I disabled/reenabled Better Code Blocks v2.0.1. No change.
I really don't want to resort to special unicode characters to represent the angle brackets, such as ⟪⟫.
Am I doing something wrong?
The issue appears to be the CodePerfect plugin, I can re-create the behavior with that plugin enabled, but not when its disabled
I can confirm. I disabled CodePerfect and the text and angle brackets display.
