Backticks make code disappear in editor pane (confusing title, sorry)
Joplin 3.4.12 (prod, win32)
Device: win32, AMD Ryzen 7 5800H with Radeon Graphics
Client ID: 0eba133bf40e422fa62146c80df1b9b3
Profile Version: 48
Alternative instance ID: -
Revision: e9a9f68
AlertsPerfect: 1.0.1
Backup: 1.4.3
Better Code Blocks: 2.0.1
CodePerfect: 1.0.2
Csv Import: 1.0.1
Editor Themes: 1.0.2
Extra Markdown editor settings: 1.11.0
Freehand Drawing: 3.1.0
Google Fonts Plugin: 1.0.0
Headings 4 to 6: 1.0.1
Hotstrings & Hotkeys: 1.0.1
Insert Date: 1.0.1
Markdown Emoji Autocomplete: 1.1.0
Math Mode: 0.8.3
Pseudocode Support: 0.1.0
Search & Replace: 2.2.0
Table Formatter Plugin: 1.2.1
Templates: 3.0.0
Text Colorize: 1.2.5
OneDrive
I think I have some disconnect in settings or something. When I enter 3 backticks, the block disappears. It happens if I enter "math" or any other designator or none at all.
So if I enter ````math the moment I enter the ``` to close the block the whole thing disappears in the editor pane. Nothing ever shows in the display pane.
I'm trying to define some syntax that includes <> characters, but I can't. I have not added anything to userchrome.css but I do have userstyle.css updates, but nothing to hide code segments. Any idea what setting or plugin might be doing this?
This behavior is from the "Better Code Blocks" extension that you have installed
IIRC you can disable code block rendering in the plugin's settings to disable that behavior
That worked. Thanks
