Hi
When opening a calendar using Firefox 135.0.1, the Joplin link does not show as a link or appear highlighted.
I also tested it using Google Chrome v 133 with the same negative result.
I am running over web-based Google Calendar in Ubuntu 24.04
Again, this work very well if I put this Joplin link in the firefox's address bar.
It works in address bar by default
That is correct. This script doesn't have anything to do with what browsers handle on their address bar. It's only about clickable application links from within Google Calendar.
Eduardo, I will check into your issues sometime this week, to see if there's anything I can do to fix them. Thank you for the report.
Sorry, I've had no time available to look at this. Higher priority things are taking up my time. Hopefully, I can look at it sometime this spring.
