Click to add tags in V-1.2.6
The "Click to add tags" at the Bottom of editor has take up a lot of space In V-1.2.6.
It would be great to let “Click to add tags” come after "Insert Time".
Hi, I think the current location and appearance of "click to add tags" is a constant distraction when working with notes. It almost seems like part of the note text. I'm in dark mode if it matters.
I find this very distracting too, especially as I have no need for tags.
I have added
a.button[title="Tags"] {
display: none !important;
to my userchrom.css whch appears to remove the Tag button.
What do I have to add to remove the "Click to add tags..."?
Once again the problem is that the div does not have a proper name, thus you have to use a selector to target the element.
The problem with this approach is that it could also match another element (e.g. in a different screen).
Put this in userchrome.css:
#react-root > div > div > div.resizableLayoutItem.rli-root > div.resizableLayoutItem.rli-editor > div > div > div > div:nth-child(4) {
Thank you but sadly that hasn't worked.
I did stop and restart Joplin after writing userchrome.css which was edited via Tools > Options > Appearance > Show Advanced Settings > Edit
I’m using Joplin Portable 1.3.18 (prod, win32)
I was using git master (1.4.x), so maybe there's a difference there.
I've also added the div here:
This worked for me, but stopped working after I installed the tabs plug-in...
