Is there a way to change the default shortcut (Ctrl+Alt+J) that opens Joplin window?
Is this set by Joplin at all? I don’t recall setting this explicitly and noticed when I used the same shortcut in an IDE while Joplin was running in the background.
Joplin 1.0.197 (prod, linux)
Client ID: 25b34e92c12c4fe1a6f14a72571360d3
Sync Version: 1
Profile Version: 28
Revision: 719afba (master)
Currently this is not supported but will be sure in future versions
Hey @serpro69 ,
That feature is being worked on as part of GSoC.
this is the topic in regard to the above-mentioned topic.
Anything on how to do this, how it shall be done, what features in shell include etc. is discussed here if an existing topic hasn’t been created yet, see idea description below.
Your interest in this idea shall be announced here, otherwise, it gets easily lost as we would need to remember each introduction.
This topic is used to update the specification of the idea as well, even if there is an existing topic, so interested students, wa…
