i'm trying to decrypt a single file using the command e2ee decrypt-file but i get "invalid encryption identifier error"
but when i run the status command it says encryption is enabled..
~ > joplin e2ee decrypt-file "/home/user/JNP/0aa688c02659473abae74811f50ee2c8.sync-conflict-20231219-161231-4W4LESE.md"
Invalid encryption identifier. Data is not actually encrypted? ID was: id: 0
~ > joplin e2ee status "/home/user/JNP/0aa688c02659473abae74811f50ee2c8.sync-conflict-20231219-161231-4W4LESE.md"
Encryption is: Enabled
am i doing the command wrong?
can someone tell me what i'm missing and how to get it to work?
The error says id was 0, which suggests the particular encrypted item might be corrupted. Though I haven't ever tried using the cli to decrypt an item
i tried other notes different encryption id, same issue
running e2ee status says encryption is enabled
~ > joplin e2ee decrypt-file "/home/user/JNP/8000b7a2fbf8425b8f061d3e41fe1cdd.md"
Invalid encryption identifier. Data is not actually encrypted? ID was: id: 8
~ > joplin e2ee decrypt-file "/home/user/JNP/aea9be3ba89a409895b65733d144204f.md"
Invalid encryption identifier. Data is not actually encrypted? ID was: id: a
Does the md file have a encryption_cipher value which starts with JED?
I'm not sure then. Maybe you could try asking ChatGPT
i found that
and i followed the steps and also ended up like OP with
Invalid block size:
i don't know where to go from there..
