Environment
Platform: Desktop
OS: Ubuntu 19.04
- Before merging upstream branch build tests were running fine and now I just merged my master branch with upstream/master branch and tried running
npm testand I got this errors:
zkesarani@zkesarani-VB:~/Dev/joplin/CliClient$ npm test
> joplin@1.0.163 test /home/zkesarani/Dev/joplin/CliClient
> gulp buildTests -L && jasmine --config=tests/support/jasmine.json
Testing with sync target: memory
Randomized with seed 45363
Started
...............14:12:22 Error: Error: SQLITE_ERROR: no such column: items.type_:
SELECT items.`id`,items.`parent_id`,items.`title`,items.`body`,items.`created_time`,items.`updated_time`,items.`is_conflict`,items.`latitude`,items.`longitude`,items.`altitude`,items.`author`,items.`source_url`,items.`is_todo`,items.`todo_due`,items.`todo_completed`,items.`source`,items.`source_application`,items.`application_data`,items.`order`,items.`user_created_time`,items.`user_updated_time`,items.`encryption_cipher_text`,items.`encryption_applied`,items.`markup_language`,items.`is_shared`,items.`type_`,items.`type_`,items.`type_`
FROM `notes` items
WHERE id NOT IN (
SELECT item_id FROM sync_items WHERE sync_target = 1
AND is_conflict = 0 AND encryption_applied = 0
ORDER BY items.updated_time DESC
LIMIT 100
at DatabaseDriverNode.sqliteErrorToJsError (/home/zkesarani/Dev/joplin/CliClient/tests-build/lib/database-driver-node.js:21:18)
at JoplinDatabase.sqliteErrorToJsError (/home/zkesarani/Dev/joplin/CliClient/tests-build/lib/database.js:22:24)
at JoplinDatabase.tryCall (/home/zkesarani/Dev/joplin/CliClient/tests-build/lib/database.js:90:17)
at processTicksAndRejections (internal/process/task_queues.js:97:5) {
code: 'SQLITE_ERROR'
14:12:22 There was some errors:
FROM `notes` items
WHERE id NOT IN (
LIMIT 100
Error: No encryptable item on sync target
at allSyncTargetItemsEncrypted (/home/zkesarani/Dev/joplin/CliClient/tests-build/test-utils.js:419:25)
at async /home/zkesarani/Dev/joplin/CliClient/tests-build/services_ResourceService.js:177:10
at async UserContext.<anonymous> (/home/zkesarani/Dev/joplin/CliClient/tests-build/test-utils.js:380:4)
F.......................................................................................................
Failures:
1) synchronizer should not download resources over the limit
Message:
Expected 0 to be 2.
Stack:
Error: Expected 0 to be 2.
at <Jasmine>
at /home/zkesarani/Dev/joplin-upstream/joplin/CliClient/tests-build/synchronizer.js:1323:28
at <Jasmine>
2) synchronizer should not consider it is a conflict if neither the title nor body of the note have changed
Message:
Expected 0 to be 1, 'Test has thrown an exception - see above error'.
Stack:
Error: Expected 0 to be 1, 'Test has thrown an exception - see above error'.
at <Jasmine>
at UserContext.<anonymous> (/home/zkesarani/Dev/joplin-upstream/joplin/CliClient/tests-build/test-utils.js:386:15)
at <Jasmine>
3) synchronizer should encryt resources
Message:
Unhandled promise rejection: Error: Resource ID not provided
Stack:
at Function.byResourceId (/home/zkesarani/Dev/joplin-upstream/joplin/CliClient/tests-build/lib/models/ResourceLocalState.js:14:26)
at Function.localState (/home/zkesarani/Dev/joplin-upstream/joplin/CliClient/tests-build/lib/models/Resource.js:222:29)
at ResourceFetcher.startDownload_ (/home/zkesarani/Dev/joplin-upstream/joplin/CliClient/tests-build/lib/services/ResourceFetcher.js:123:37)
at <Jasmine>
4) synchronizer should skip items that cannot be synced
Message:
Expected 0 to be 1.
Stack:
Error: Expected 0 to be 1.
at <Jasmine>
at /home/zkesarani/Dev/joplin-upstream/joplin/CliClient/tests-build/synchronizer.js:712:24
at <Jasmine>
5) synchronizer should decrypt the resource metadata, but not try to decrypt the file, if it is not present
Message:
Stack:
at <Jasmine>
at <Jasmine>
6) synchronizer should not upload any item if encryption was enabled, and items have not been decrypted, and then encryption disabled
Message:
Expected false to be true.
Stack:
Error: Expected false to be true.
at <Jasmine>
at /home/zkesarani/Dev/joplin-upstream/joplin/CliClient/tests-build/synchronizer.js:1025:47
at <Jasmine>
7) synchronizer should allow duplicate folder titles
Message:
Stack:
at <Jasmine>
at <Jasmine>
8) synchronizer should always handle conflict if local or remote are encrypted
Message:
Stack:
at <Jasmine>
at <Jasmine>
9) synchronizer should resolve conflict if remote folder has been deleted, but note has been added to folder locally
Message:
Expected 2 to be 1.
Stack:
Error: Expected 2 to be 1.
at <Jasmine>
at /home/zkesarani/Dev/joplin-upstream/joplin/CliClient/tests-build/synchronizer.js:362:24
at <Jasmine>
10) synchronizer should delete resources
Message:
Expected 0 to be 1.
Stack:
at <Jasmine>
at /home/zkesarani/Dev/joplin-upstream/joplin/CliClient/tests-build/synchronizer.js:947:31
at <Jasmine>
11) synchronizer should not wipe out user data when syncing with an empty target
Message:
Expected 10 to be 0.
Stack:
Error: Expected 10 to be 0.
at <Jasmine>
at /home/zkesarani/Dev/joplin-upstream/joplin/CliClient/tests-build/synchronizer.js:1496:37
at <Jasmine>
12) synchronizer should delete remote notes
Message:
Expected 0 to be 1.
Stack:
at <Jasmine>
at /home/zkesarani/Dev/joplin-upstream/joplin/CliClient/tests-build/synchronizer.js:258:26
at <Jasmine>
13) synchronizer should handle conflict when remote note is deleted then local note is modified
Message:
Expected 0 to be 1.
Stack:
at <Jasmine>
at /home/zkesarani/Dev/joplin-upstream/joplin/CliClient/tests-build/synchronizer.js:452:34
at <Jasmine>
14) synchronizer should set the resource file size after decryption
Message:
Stack:
at <Jasmine>
15) synchronizer should encrypt remote resources after encryption has been enabled
Message:
Stack:
at <Jasmine>
at <Jasmine>
16) synchronizer should resolve folders conflicts
Message:
Stack:
at <Jasmine>
at <Jasmine>
17) synchronizer should upload decrypted items to sync target after encryption disabled
Message:
Stack:
at <Jasmine>
at <Jasmine>
18) synchronizer should resolve conflict if note has been deleted remotely and locally
Message:
Expected 1 to be 0.
Stack:
Error: Expected 1 to be 0.
at <Jasmine>
at localNotesFoldersSameAsRemote (/home/zkesarani/Dev/joplin-upstream/joplin/CliClient/tests-build/synchronizer.js:66:25)
at <Jasmine>
Message:
Expected Error to be null. Tip: To check for deep equality, use .toEqual() instead of .toBe().
Stack:
Error: Expected Error to be null. Tip: To check for deep equality, use .toEqual() instead of .toBe().
at <Jasmine>
at localNotesFoldersSameAsRemote (/home/zkesarani/Dev/joplin-upstream/joplin/CliClient/tests-build/synchronizer.js:85:16)
at <Jasmine>
19) synchronizer should sync resources
Message:
Expected 0 to be 3.
Stack:
Error: Expected 0 to be 3.
at <Jasmine>
at /home/zkesarani/Dev/joplin-upstream/joplin/CliClient/tests-build/synchronizer.js:857:56
at <Jasmine>
20) synchronizer should not upload a resource if it has not been fetched yet
Message:
Expected 0 to be 1.
Stack:
at <Jasmine>
at /home/zkesarani/Dev/joplin-upstream/joplin/CliClient/tests-build/synchronizer.js:1352:44
at <Jasmine>
21) synchronizer should delete local folder
Message:
Expected 2 to be 0.
Stack:
Error: Expected 2 to be 0.
at <Jasmine>
at <Jasmine>
Message:
Stack:
at <Jasmine>
at <Jasmine>
22) synchronizer items should be downloaded again when user cancels in the middle of delta operation
Message:
Expected 0 to be 1.
Stack:
at <Jasmine>
at /home/zkesarani/Dev/joplin-upstream/joplin/CliClient/tests-build/synchronizer.js:692:24
at async UserContext.<anonymous> (/home/zkesarani/Dev/joplin-upstream/joplin/CliClient/tests-build/test-utils.js:380:4)
23) synchronizer should create remote items
Message:
Expected 2 to be 0.
Stack:
at <Jasmine>
at async /home/zkesarani/Dev/joplin-upstream/joplin/CliClient/tests-build/synchronizer.js:111:3
Message:
Stack:
at <Jasmine>
24) synchronizer should update remote items
Message:
Expected 2 to be 0.
Stack:
at <Jasmine>
at async /home/zkesarani/Dev/joplin-upstream/joplin/CliClient/tests-build/synchronizer.js:124:3
Message:
Stack:
at <Jasmine>
25) synchronizer should not save revisions when deleting a note via sync
Message:
Expected 0 to be 1.
Stack:
at <Jasmine>
at /home/zkesarani/Dev/joplin-upstream/joplin/CliClient/tests-build/synchronizer.js:1218:27
26) synchronizer should set the resource file size if it is missing
Message:
Stack:
at <Jasmine>
27) synchronizer should cross delete all folders
Message:
Expected 1 to be 0.
Stack:
at <Jasmine>
at /home/zkesarani/Dev/joplin-upstream/joplin/CliClient/tests-build/synchronizer.js:424:25
28) synchronizer should create a new Welcome notebook on each client
Message:
Expected 1 to be 2.
Stack:
Error: Expected 1 to be 2.
at <Jasmine>
at /home/zkesarani/Dev/joplin-upstream/joplin/CliClient/tests-build/synchronizer.js:1163:28
29) synchronizer should delete local notes
Message:
Expected 3 to be 2.
Stack:
Error: Expected 3 to be 2.
at <Jasmine>
at /home/zkesarani/Dev/joplin-upstream/joplin/CliClient/tests-build/synchronizer.js:303:24
30) synchronizer should not sync notes with conflicts
Message:
Expected 0 to be 1.
Stack:
at <Jasmine>
at /home/zkesarani/Dev/joplin-upstream/joplin/CliClient/tests-build/synchronizer.js:592:26
31) synchronizer should not encrypt notes that are shared
Message:
Stack:
at <Jasmine>
32) synchronizer should encrypt existing notes too when enabling E2EE
Message:
Stack:
at <Jasmine>
33) synchronizer should clear a lock if it was created by the same app as the current one
Message:
Stack:
at <Jasmine>
34) synchronizer should handle resource download errors
Message:
Stack:
35) synchronizer should create remote items with UTF-8 content
Message:
Expected 2 to be 0.
Stack:
at <Jasmine>
at async /home/zkesarani/Dev/joplin-upstream/joplin/CliClient/tests-build/synchronizer.js:1116:3
Message:
Stack:
at <Jasmine>
36) synchronizer should not save revisions when an item_change has been generated as a result of a sync
Message:
Unhandled promise rejection: Error: No such note: cef6fd938447461183961ecf91b45e7c
Stack:
at Function.noteIsOlderThan (/home/zkesarani/Dev/joplin-upstream/joplin/CliClient/tests-build/lib/models/Note.js:563:17)
at async RevisionService.isOldNote (/home/zkesarani/Dev/joplin-upstream/joplin/CliClient/tests-build/lib/services/RevisionService.js:41:17)
37) synchronizer should stop trying to decrypt item after a few attempts
Message:
Stack:
at <Jasmine>
at runNextTicks (internal/process/task_queues.js:62:5)
at listOnTimeout (internal/timers.js:518:9)
38) synchronizer should resolve note conflicts
Message:
Stack:
at <Jasmine>
39) synchronizer should sync encrypted tags
Message:
Stack:
at <Jasmine>
40) synchronizer should handle case when new rev is created on client, then older rev arrives later via sync
Message:
Unhandled promise rejection: Error: No such note: 8a7f5c4b67ec464e970b91b9c4bad574
Stack:
41) synchronizer should update local items
Message:
Stack:
at <Jasmine>
42) synchronizer should handle conflict when remote folder is deleted then local folder is renamed
Message:
Expected 3 to be 1.
Stack:
Error: Expected 3 to be 1.
at <Jasmine>
at /home/zkesarani/Dev/joplin-upstream/joplin/CliClient/tests-build/synchronizer.js:487:24
at <Jasmine>
43) synchronizer should not save revisions when updating a note via sync
Message:
Unhandled promise rejection: Error: No such note: 0f7cced130c844e1a390b4b4759a5280
Stack:
at <Jasmine>
44) synchronizer should not try to delete on remote conflicted notes that have been deleted
Message:
Stack:
at <Jasmine>
45) synchronizer notes and folders should get encrypted when encryption is enabled
Message:
Stack:
at <Jasmine>
at <Jasmine>
46) synchronizer should update remote items but not pull remote changes
Message:
Stack:
at <Jasmine>
at <Jasmine>
47) synchronizer should sync tags
Message:
Stack:
at <Jasmine>
at shoudSyncTagTest (/home/zkesarani/Dev/joplin-upstream/joplin/CliClient/tests-build/synchronizer.js:547:23)
at <Jasmine>
48) synchronizer should enable encryption automatically when downloading new master key (and none was previously available)
Message:
Stack:
at <Jasmine>
at /home/zkesarani/Dev/joplin-upstream/joplin/CliClient/tests-build/synchronizer.js:775:47
at <Jasmine>
49) services_ResourceService should not delete resources that are associated with an encrypted note
Message:
Stack:
at <Jasmine>
at <Jasmine>
275 specs, 49 failures
Finished in 166.007 seconds
Randomized with seed 74008 (jasmine --random=true --seed=74008)
npm ERR! Test failed. See above for more details.
- after then I created new directory and clone the repo using
git clone https://github.com/laurent22/joplin.gitand rannpm installthennpm testin CliClient folder and got same error as above.
Looks like some PR got merged with failed build tests, can anyone please confirm this issue by try merging and running build tests so I can know if this issue is in my system or it’s problem with upstream/branch
