This is related to my message from Febr 16, I did a complete reinstall and it seemed to work flawlessly for some time. Now I got the same problem again.
I am using vs 140 on desktop (linux-mint) and replicating encrypted to an android (7.1.1) device vs. 1.0.241
I noticed attached files in notes are not synchronized in some cases. If you try to open the entries you get missing file messages.
I hope this debug information will help to locate the problem:
Error message shown on mobile device:
Created remote items: 2.
Completed: 12/04/2019 19:24
Last error: Error: PUT .resource/b0a5470d9c38447b88c90e9d813d9b6a: expected filesize 11846781 got 671744 (Exception Sabre\DAV\Exception\BadRequest) (400): <?xml version="1.0" encoding="utf-8"?> <d:error xmlns:d=“DAV:” xmlns:s=“http://sabredav.org/ns”> <s:exception>Sabre\DAV\Exception\BadRequest</s:exception> <s:message>expected filesize 11846781 got 671744</s:message> </d:error>
Note the expected filesize ist the size of the unencrypted and the filesicze “got” is the size of the encrypted file that failed to replicate.
Last sync-report from mobile device - some minutes earlier - start of file, I can send the whole if that helps and you tell me how to post it in the forum:
Date,Level,Message
04-12T14:21:25,30,""“Saving settings…”"
04-12T14:21:25,30,""“Reducer action”, “SETTING_UPDATE_ONE”"
04-12T14:21:24,30,""“SearchEngine: Updating FTS table…”"
04-12T14:21:24,30,""“Reducer action”, “FOLDER_UPDATE_ALL”"
04-12T14:21:24,30,""“Reducer action”, “SYNC_COMPLETED”"
04-12T14:21:24,30,""“Total resources: 713"”
04-12T14:21:24,30,""“Total notes: 150"”
04-12T14:21:24,30,""“Total folders: 33"”
04-12T14:21:24,30,""“Operations completed: “”
04-12T14:21:21,30,”"“Reducer action”, “SYNC_STARTED”"
04-12T14:21:21,30,""“Starting scheduled sync”"
04-12T14:21:21,30,""“Preparing scheduled sync”"
04-12T14:21:17,30,""“Settings have been saved.”"
04-12T14:21:16,30,""“Reducer action”, “DECRYPTION_WORKER_SET”"
04-12T14:21:16,30,""“DecryptionWorker: completed decryption.”"
04-12T14:21:16,30,""“Scheduling sync operation…”"
04-12T14:21:16,30,""“Reducer action”, “EVENT_NOTE_ALARM_FIELD_CHANGE”"
04-12T14:21:16,30,""“Reducer action”, “NOTE_UPDATE_ONE”"
04-12T14:21:16,30,""“Saving settings…”"
04-12T14:21:15,30,""“Reducer action”, “DECRYPTION_WORKER_SET”"
04-12T14:21:15,30,""“DecryptionWorker: starting decryption…”"
04-12T14:21:15,30,""“Reducer action”, “FOLDER_UPDATE_ALL”"
04-12T14:21:15,30,""“Reducer action”, “SETTING_UPDATE_ONE”"
04-12T14:21:15,30,""“Reducer action”, “SYNC_COMPLETED”"
04-12T14:21:15,30,""“Total resources: 713"”
04-12T14:21:15,30,""“Total notes: 150"”
04-12T14:21:15,30,""“Total folders: 33"”
04-12T14:21:15,30,""“updateLocal: 1"”
04-12T14:21:15,30,""“fetchingTotal: 1"”
04-12T14:21:15,30,""“Operations completed: “”
04-12T14:21:14,30,”"“Reducer action”, “SETTING_UPDATE_ONE”"
04-12T14:21:14,30,""“Reducer action”, “SYNC_GOT_ENCRYPTED_ITEM”"
04-12T14:21:14,30,""“Reducer action”, “EVENT_NOTE_ALARM_FIELD_CHANGE”"
04-12T14:21:14,30,""“Reducer action”, “NOTE_UPDATE_ONE”"
04-12T14:21:10,30,""“Reducer action”, “NOTE_UPDATE_ALL”"
04-12T14:21:09,30,""“Reducer action”, “SYNC_STARTED”"
04-12T14:21:09,30,""“Starting scheduled sync”"
04-12T14:21:09,30,""“Preparing scheduled sync”"
04-12T14:21:09,30,""“Scheduling sync operation…”"
04-12T14:21:09,30,""“Running background sync on timer…”"
04-12T12:20:43,30,""“Reducer action”, “NOTE_UPDATE_ALL”"
04-12T12:15:59,30,""“Reducer action”, “FOLDER_UPDATE_ALL”"
04-12T12:15:59,30,""“Reducer action”, “SYNC_COMPLETED”"
04-12T12:15:59,30,""“Total resources: 713"”
04-12T12:15:59,30,""“Total notes: 150"”
04-12T12:15:59,30,""“Total folders: 33"”
04-12T12:15:59,30,""“Operations completed: “”
04-12T12:15:59,10,”"“TypeError: Network request failed
onerror@index.android.bundle:133:4815
value@index.android.bundle:118:1505
value@index.android.bundle:117:6656
value@index.android.bundle:117:3396
index.android.bundle:117:9584
value@index.android.bundle:46:1389
value@index.android.bundle:25:3449
index.android.bundle:25:960
value@index.android.bundle:25:2703
value@index.android.bundle:25:932
[native code]”"
04-12T12:15:43,30,""“Reducer action”, “NAV_GO, Note”"
04-12T12:15:41,30,""“Reducer action”, “NAV_BACK”"
04-12T12:15:34,30,""“Reducer action”, “NAV_GO, Note”"
04-12T12:15:32,30,""“Reducer action”, “SIDE_MENU_CLOSE”"
04-12T12:15:22,30,""“Reducer action”, “SIDE_MENU_OPEN”"
04-12T12:15:22,30,""“Reducer action”, “SIDE_MENU_TOGGLE”"
04-12T12:15:20,30,""“Reducer action”, “NAV_BACK”"
04-12T12:13:02,30,""“Reducer action”, “NAV_GO, Note”"
04-12T12:13:00,30,""“Reducer action”, “NAV_BACK”"
04-12T12:12:50,30,""“Reducer action”, “NAV_GO, Note”"
04-12T12:12:48,30,""“Reducer action”, “SIDE_MENU_CLOSE”"
04-12T12:12:48,30,""“Reducer action”, “NAV_GO, Notes”"
04-12T12:12:41,30,""“Reducer action”, “SIDE_MENU_OPEN”"
04-12T12:12:41,30,""“Reducer action”, “SIDE_MENU_TOGGLE”"
04-12T12:12:37,30,""“Settings have been saved.”"
04-12T12:12:37,30,""“Reducer action”, “NOTE_UPDATE_ALL”"
04-12T12:12:36,30,""“Reducer action”, “SYNC_STARTED”"
04-12T12:12:36,30,""“Saving settings…”"
04-12T12:12:36,30,""“Starting scheduled sync”"
04-12T12:12:36,30,""“Preparing scheduled sync”"
04-12T12:12:36,30,""“Scheduling sync operation…”"
04-12T12:12:36,30,""“Running background sync on timer…”"
04-12T12:12:36,30,""“Garbage collecting alarms…”"
04-12T11:11:26,30,""“Reducer action”, “FOLDER_UPDATE_ALL”"
04-12T11:11:26,30,""“Reducer action”, “SETTING_UPDATE_ONE”"
04-12T11:10:18,30,""“Reducer action”, “SYNC_COMPLETED”"
04-12T11:10:18,30,""“Total resources: 713"”
04-12T11:10:18,30,""“Total notes: 150"”
04-12T11:10:18,30,""“Total folders: 33"”
04-12T11:10:18,30,""“fetchingTotal: -”"
04-12T11:10:18,30,""“Operations completed: “”
04-12T11:10:12,30,”"“Reducer action”, “SETTING_UPDATE_ONE”"
04-12T11:10:07,30,""“Reducer action”, “FOLDER_UPDATE_ALL”"
04-12T11:09:11,30,""“Reducer action”, “SYNC_STARTED”"
04-12T11:09:10,30,""“Starting scheduled sync”"
04-12T11:09:10,30,""“Scheduling sync operation…”"
04-12T11:09:10,30,""“Preparing scheduled sync”"
04-12T11:09:10,30,""“Running background sync on timer…”"
04-12T11:09:10,30,""“Reducer action”, “SETTING_UPDATE_ONE”"
04-12T11:05:06,30,""“Reducer action”, “SYNC_COMPLETED”"
04-12T11:05:06,30,""“Total resources: 713"”
04-12T11:05:06,30,""“Total notes: 150"”
04-12T11:05:06,30,""“Total folders: 33"”
04-12T11:05:06,30,""“fetchingTotal: -”"
04-12T11:05:06,30,""“Operations completed: “”
04-12T11:03:40,30,”"“Reducer action”, “SETTING_UPDATE_ONE”"
04-12T11:00:38,30,""“Reducer action”, “NOTE_UPDATE_ALL”"
04-12T11:00:37,30,""“Reducer action”, “SYNC_STARTED”"
04-12T11:00:37,30,""“Starting scheduled sync”"
04-12T11:00:37,30,""“Preparing scheduled sync”"
04-12T11:00:37,30,""“Scheduling sync operation…”"
04-12T11:00:37,30,""“Running background sync on timer…”"
04-12T10:55:31,30,""“ResourceService::deleteOrphanResources:”, “[]”"
04-12T10:55:31,30,""“ResourceService::indexNoteResources: Completed”"
04-12T10:55:31,30,""“ResourceService::indexNoteResources: Start”"
04-12T10:55:24,30,""“Reducer action”, “SIDE_MENU_CLOSE”"
04-12T10:55:20,30,""“Reducer action”, “DECRYPTION_WORKER_SET”"
04-12T10:55:20,30,""“DecryptionWorker: completed decryption.”"
04-12T10:55:19,30,""“Reducer action”, “DECRYPTION_WORKER_SET”"
04-12T10:55:19,30,""“DecryptionWorker: starting decryption…”"
04-12T10:55:19,30,""“Settings have been saved.”"
04-12T10:55:19,30,""“Saving settings…”"
04-12T10:55:18,30,""“Reducer action”, “FOLDER_UPDATE_ALL”"
04-12T10:55:18,30,""“Garbage collecting alarms…”"
04-12T10:55:18,30,""“Updating all notifications…”"
04-12T10:55:18,30,""“Reducer action”, “SETTING_UPDATE_ONE”"
04-12T10:55:18,30,""“Reducer action”, “SYNC_COMPLETED”"
04-12T10:55:18,30,""“Total resources: 713"”
04-12T10:55:18,30,""“Total notes: 150"”
04-12T10:55:18,30,""“Total folders: 33"”
04-12T10:55:18,30,""“fetchingTotal: -”"
04-12T10:55:18,30,""“Operations completed: “”
04-12T10:55:18,30,”"“Saving settings…”"
04-12T10:55:17,30,""“Reducer action”, “SETTING_UPDATE_ONE”"
04-12T10:55:12,30,""“Reducer action”, “SIDE_MENU_OPEN”"
04-12T10:55:12,30,""“Reducer action”, “SIDE_MENU_TOGGLE”"
04-12T10:55:11,30,""“SearchEngine: Updated FTS table in 25ms”"
04-12T10:55:11,30,""“Reducer action”, “SYNC_STARTED”"
04-12T10:55:11,30,""“Starting scheduled sync”"
04-12T10:55:11,30,""“Preparing scheduled sync”"
04-12T10:55:10,30,""“SearchEngine: Updating FTS table…”"
04-12T10:55:05,30,""“Reducer action”, “NAV_GO, Note”"
04-12T10:55:02,30,""“Reducer action”, “DECRYPTION_WORKER_SET”"
04-12T10:55:02,30,""“DecryptionWorker: completed decryption.”"
04-12T10:55:01,30,""“Reducer action”, “DECRYPTION_WORKER_SET”"
04-12T10:55:01,30,""“DecryptionWorker: starting decryption…”"
04-12T10:55:01,30,""“Reducer action”, “NOTE_UPDATE_ALL”"
04-12T10:55:01,30,""“ResourceFetcher: Auto-added resources: 0"”
04-12T10:55:00,30,""“Reducer action”, “APP_STATE_SET”"
04-12T10:55:00,30,""“Application initialized”"
04-12T10:55:00,30,""“Scheduling sync operation…”"
04-12T10:55:00,30,""“Reducer action”, “NAV_GO, Notes”"
04-12T10:55:00,30,""“Reducer action”, “FOLDER_SET_COLLAPSED_ALL”"
04-12T10:55:00,30,""“Reducer action”, “MASTERKEY_UPDATE_ALL”"
04-12T10:55:00,30,""“Reducer action”, “TAG_UPDATE_ALL”"
04-12T10:55:00,30,""“Reducer action”, “FOLDER_UPDATE_ALL”"
04-12T10:55:00,30,""“Reducer action”, “MASTERKEY_REMOVE_NOT_LOADED”"
04-12T10:55:00,30,""“Loaded master keys: 1"”
04-12T10:55:00,30,""“Trying to load 1 master keys…”"
04-12T10:55:00,30,""“Loading folders…”"
04-12T10:54:57,30,""“Trying to load 1 master keys…”"
04-12T10:54:57,30,""“Sync target: 5"”
04-12T10:54:57,30,""“Reducer action”, “SETTING_UPDATE_ALL”"
04-12T10:54:57,30,""“Loading settings…”"
04-12T10:54:57,30,""“Database is ready.”"
04-12T10:54:57,30,""“Current database version”, “18"”
04-12T10:54:57,30,""“Checking for database schema update…”"
04-12T10:54:57,30,""“Database was open successfully”"
04-12T10:54:57,30,""“Starting application net.cozic.joplin-mobile (prod)”"
04-12T10:54:57,30,"""====================================""
04-11T10:52:01,30,""“Reducer action”, “NOTE_UPDATE_ALL”"
04-11T10:51:59,30,""“Reducer action”, “NAV_BACK”"
04-11T10:51:43,30,""“Settings have been saved.”"
04-11T10:51:42,30,""“Reducer action”, “NAV_GO, Note”"
04-11T10:51:41,30,""“Reducer action”, “NOTE_UPDATE_ALL”"
04-11T10:51:40,30,""“Reducer action”, “NOTE_UPDATE_ALL”"
04-11T10:51:40,30,""“Saving settings…”"
04-11T10:51:40,30,""“Reducer action”, “SETTING_UPDATE_ONE”"
04-11T10:51:39,30,""“Reducer action”, “SIDE_MENU_CLOSE”"
04-11T10:51:39,30,""“Reducer action”, “NAV_GO, Notes”"
04-11T10:51:37,30,""“Reducer action”, “SIDE_MENU_OPEN”"
04-11T10:51:37,30,""“Reducer action”, “SIDE_MENU_TOGGLE”"
04-11T10:51:37,30,""“Settings have been saved.”"
04-11T10:51:35,30,""“Reducer action”, “NOTE_UPDATE_ALL”"
04-11T10:51:34,30,""“Reducer action”, “NOTE_UPDATE_ALL”"
04-11T10:51:34,30,""“Saving settings…”"
04-11T10:51:34,30,""“Reducer action”, “SETTING_UPDATE_ONE”"
04-11T10:51:34,30,""“Reducer action”, “SIDE_MENU_CLOSE”"
04-11T10:51:34,30,""“Reducer action”, “NAV_GO, Notes”"
04-11T10:51:28,30,""“Settings have been saved.”"
04-11T10:51:28,30,""“Saving settings…”"
04-11T10:51:27,30,""“Reducer action”, “FOLDER_UPDATE_ALL”"
04-11T10:51:27,30,""“Reducer action”, “SETTING_UPDATE_ONE”"
04-11T10:51:27,30,""“Reducer action”, “SYNC_COMPLETED”"
04-11T10:51:27,30,""“Total resources: 713"”
04-11T10:51:27,30,""“Total notes: 150"”
04-11T10:51:27,30,""“Total folders: 33"”
04-11T10:51:27,30,""“fetchingTotal: -”"
04-11T10:51:27,30,""“Operations completed: “”
04-11T10:51:26,30,”"“Reducer action”, “SETTING_UPDATE_ONE”"
04-11T10:51:22,30,""“Reducer action”, “SYNC_STARTED”"
04-11T10:51:22,30,""“Starting scheduled sync”"
04-11T10:51:22,30,""“Preparing scheduled sync”"
04-11T10:51:22,30,""“Scheduling sync operation…”"
04-11T10:51:15,30,""“Settings have been saved.”"
04-11T10:51:15,30,""“Saving settings…”"
04-11T10:51:15,30,""“Reducer action”, “FOLDER_UPDATE_ALL”"
04-11T10:51:14,30,""“Reducer action”, “SETTING_UPDATE_ONE”"
04-11T10:51:14,30,""“Reducer action”, “SYNC_COMPLETED”"
04-11T10:51:14,30,""“Total resources: 713"”
04-11T10:51:14,30,""“Total notes: 150"”
04-11T10:51:14,30,""“Total folders: 33"”
04-11T10:51:14,30,""“fetchingTotal: -”"
04-11T10:51:14,30,""“Operations completed: “”
04-11T10:51:14,30,”"“Reducer action”, “SETTING_UPDATE_ONE”"
04-11T10:51:10,30,""“Settings have been saved.”"
04-11T10:51:10,30,""“ResourceService::deleteOrphanResources:”, “[]”"
04-11T10:51:10,30,""“ResourceService::indexNoteResources: Completed”"
04-11T10:51:10,30,""“Reducer action”, “NOTE_UPDATE_ALL”"
04-11T10:51:10,30,""“Reducer action”, “SYNC_STARTED”"
04-11T10:51:10,30,""“Saving settings…”"
04-11T10:51:10,30,""“Starting scheduled sync”"
04-11T10:51:09,30,""“Preparing scheduled sync”"
04-11T10:51:09,30,""“Scheduling sync operation…”"
04-11T10:51:09,30,""“Running background sync on timer…”"
04-11T10:51:09,30,""“ResourceService::indexNoteResources: Start”"
04-10T22:23:06,30,""“Reducer action”, “FOLDER_UPDATE_ALL”"
04-10T22:23:06,30,""“Reducer action”, “SETTING_UPDATE_ONE”"
04-10T22:23:06,30,""“Reducer action”, “SYNC_COMPLETED”"
04-10T22:23:06,30,""“Total resources: 713"”
04-10T22:23:06,30,""“Total notes: 150"”
04-10T22:23:06,30,""“Total folders: 33"”
04-10T22:23:06,30,""“fetchingTotal: -”"
04-10T22:23:06,30,""“Operations completed: “”
04-10T22:23:06,30,”"“Reducer action”, “SETTING_UPDATE_ONE”"
04-10T22:23:03,30,""“Reducer action”, “NOTE_UPDATE_ALL”"
04-10T22:23:01,30,""“ResourceService::deleteOrphanResources:”, “[]”"
04-10T22:23:01,30,""“ResourceService::indexNoteResources: Completed”"
04-10T22:23:01,30,""“Settings have been saved.”"
04-10T22:23:01,30,""“Saving settings…”"
04-10T22:23:01,30,""“Reducer action”, “SETTING_UPDATE_ONE”"
04-10T22:23:01,30,""“Reducer action”, “NOTE_UPDATE_ALL”"
04-10T22:23:00,30,""“Reducer action”, “SYNC_STARTED”"
04-10T22:23:00,30,""“Starting scheduled sync”"
04-10T22:23:00,30,""“Preparing scheduled sync”"
04-10T22:23:00,30,""“Scheduling sync operation…”"
04-10T22:23:00,30,""“Running background sync on timer…”"
04-10T22:23:00,30,""“ResourceService::indexNoteResources: Start”"
04-10T19:33:23,30,""“Reducer action”, “NOTE_UPDATE_ALL”"
04-10T19:28:29,30,""“Settings have been saved.”"
04-10T19:28:29,30,""“Saving settings…”"
04-10T19:28:28,30,""“Reducer action”, “FOLDER_UPDATE_ALL”"
04-10T19:28:28,30,""“Reducer action”, “SETTING_UPDATE_ONE”"
04-10T19:28:28,30,""“Reducer action”, “SYNC_COMPLETED”"
04-10T19:28:28,30,""“Total resources: 713"”
04-10T19:28:28,30,""“Total notes: 150"”
04-10T19:28:28,30,""“Total folders: 33"”
04-10T19:28:28,30,""“fetchingTotal: 1"”
04-10T19:28:28,30,""“Operations completed: “”
04-10T19:28:27,30,”"“Reducer action”, “SETTING_UPDATE_ONE”"
04-10T19:28:23,30,""“Reducer action”, “SYNC_STARTED”"
04-10T19:28:23,30,""“Starting scheduled sync”"
04-10T19:28:23,30,""“Preparing scheduled sync”"
04-10T19:28:23,30,""“Scheduling sync operation…”"
04-10T19:28:10,30,""“SearchEngine: Updated FTS table in 2508ms”"
04-10T19:28:10,30,""“Settings have been saved.”"
04-10T19:28:09,30,""“Saving settings…”"
04-10T19:28:09,30,""“Reducer action”, “SETTING_UPDATE_ONE”"
04-10T19:28:07,30,""“SearchEngine: Updating FTS table…”"
04-10T19:28:05,30,""“Reducer action”, “FOLDER_UPDATE_ALL”"
04-10T19:28:05,30,""“Reducer action”, “SIDE_MENU_OPEN”"
04-10T19:28:05,30,""“Reducer action”, “SIDE_MENU_TOGGLE”"
04-10T19:28:05,30,""“Reducer action”, “SYNC_COMPLETED”"
04-10T19:28:05,30,""“Total notes: 150"”
04-10T19:28:05,30,""“Total resources: 713"”
04-10T19:28:05,30,""“Total folders: 33"”
04-10T19:28:05,30,""“updateRemote: 1"”
04-10T19:28:05,30,""“Operations completed: “”
04-10T19:28:02,30,”"“Reducer action”, “SYNC_STARTED”"
04-10T19:28:02,30,""“Starting scheduled sync”"
04-10T19:28:02,30,""“Preparing scheduled sync”"
04-10T19:27:57,30,""“Scheduling sync operation…”"
04-10T19:27:57,30,""“Reducer action”, “EVENT_NOTE_ALARM_FIELD_CHANGE”"
04-10T19:27:57,30,""“Reducer action”, “NOTE_UPDATE_ONE”"
04-10T19:25:08,30,""“Reducer action”, “NAV_GO, Note”"
04-10T19:25:06,30,""“Reducer action”, “NAV_GO, Notes”"
04-10T19:25:06,30,""“Reducer action”, “SIDE_MENU_CLOSE”"
04-10T19:24:48,30,""“Reducer action”, “SIDE_MENU_OPEN”"
04-10T19:24:48,30,""“Reducer action”, “SIDE_MENU_TOGGLE”"
04-10T19:24:30,30,""“Reducer action”, “SIDE_MENU_CLOSE”"
04-10T19:24:27,30,""“Settings have been saved.”"
04-10T19:24:27,30,""“Saving settings…”"
04-10T19:24:27,30,""“Reducer action”, “FOLDER_UPDATE_ALL”"
04-10T19:24:27,30,""“Reducer action”, “SETTING_UPDATE_ONE”"
04-10T19:24:27,30,""“Reducer action”, “SYNC_COMPLETED”"
04-10T19:24:27,30,""“Total resources: 713"”
04-10T19:24:27,30,""“Total notes: 150"”
04-10T19:24:27,30,""“Total folders: 33"”
04-10T19:24:26,30,""“fetchingTotal: -”"
04-10T19:24:26,30,""“Operations completed: “”
04-10T19:24:26,30,”"“Reducer action”, “SETTING_UPDATE_ONE”"
04-10T19:24:22,30,""“Reducer action”, “SYNC_STARTED”"
04-10T19:24:22,30,""“Starting scheduled sync”"
04-10T19:24:22,30,""“Preparing scheduled sync”"
04-10T19:24:22,30,""“Scheduling sync operation…”"
04-10T19:24:14,30,""“Reducer action”, “SIDE_MENU_OPEN”"
04-10T19:24:14,30,""“Reducer action”, “SIDE_MENU_TOGGLE”"
04-10T19:24:13,30,""“Settings have been saved.”"
04-10T19:24:13,30,""“Saving settings…”"
04-10T19:24:12,30,""“Reducer action”, “FOLDER_UPDATE_ALL”"
04-10T19:24:12,30,""“Reducer action”, “SETTING_UPDATE_ONE”"
04-10T19:24:12,30,""“Reducer action”, “SYNC_COMPLETED”"
04-10T19:24:12,30,""“Total resources: 713"”
04-10T19:24:12,30,""“Total notes: 150"”
04-10T19:24:12,30,""“Total folders: 33"”
04-10T19:24:12,30,""“fetchingTotal: -”"
04-10T19:24:12,30,""“Operations completed: “”
04-10T19:24:11,30,”"“Reducer action”, “SETTING_UPDATE_ONE”"
04-10T19:24:08,30,""“Settings have been saved.”"
04-10T19:24:08,30,""“Reducer action”, “NOTE_UPDATE_ALL”"
04-10T19:24:07,30,""“Reducer action”, “SYNC_STARTED”"
04-10T19:24:07,30,""“Saving settings…”"
04-10T19:24:07,30,""“Starting scheduled sync”"
04-10T19:24:07,30,""“Preparing scheduled sync”"
04-10T19:24:07,30,""“Scheduling sync operation…”"
04-10T19:24:07,30,""“Running background sync on timer…”"
04-10T18:20:41,30,""“Reducer action”, “FOLDER_UPDATE_ALL”"
04-10T18:20:34,30,""“Reducer action”, “SETTING_UPDATE_ONE”"
04-10T18:20:34,30,""“Reducer action”, “SYNC_COMPLETED”"
04-10T18:20:34,30,""“Total resources: 713"”
04-10T18:20:34,30,""“Total notes: 150"”
04-10T18:20:34,30,""“Total folders: 33"”
04-10T18:20:34,30,""“fetchingTotal: -”"
04-10T18:20:34,30,""“Operations completed: “”
04-10T18:20:33,30,”"“Reducer action”, “SETTING_UPDATE_ONE”"
04-10T18:20:29,30,""“Reducer action”, “FOLDER_UPDATE_ALL”"
04-10T18:19:25,30,""“Reducer action”, “SYNC_STARTED”"
04-10T18:19:25,30,""“Starting scheduled sync”"
04-10T18:19:25,30,""“Preparing scheduled sync”"
04-10T18:19:25,30,""“Scheduling sync operation…”"
04-10T18:19:25,30,""“Running background sync on timer…”"
04-10T18:19:25,30,""“Reducer action”, “SETTING_UPDATE_ONE”"
04-10T18:15:28,30,""“Reducer action”, “SYNC_COMPLETED”"
04-10T18:15:28,30,""“Total resources: 713"”
04-10T18:15:28,30,""“Total notes: 150"”
04-10T18:15:28,30,""“Total folders: 33"”
04-10T18:15:28,30,""“fetchingTotal: -”"
04-10T18:15:28,30,""“Operations completed: “”
04-10T18:15:28,30,”"“Reducer action”, “SETTING_UPDATE_ONE”"
04-10T18:12:28,30,""“Reducer action”, “NOTE_UPDATE_ALL”"
04-10T18:12:27,30,""“Reducer action”, “SYNC_STARTED”"
04-10T18:12:27,30,""“Starting scheduled sync”"
04-10T18:12:27,30,""“Preparing scheduled sync”"
04-10T18:12:27,30,""“Scheduling sync operation…”"
04-10T18:12:27,30,""“Running background sync on timer…”"
04-10T18:07:05,30,""“Reducer action”, “NAV_GO, Note”"
04-10T18:07:03,30,""“Reducer action”, “SIDE_MENU_CLOSE”"
04-10T18:07:03,30,""“Reducer action”, “NAV_GO, Notes”"
04-10T18:07:00,30,""“Reducer action”, “SIDE_MENU_OPEN”"
04-10T18:07:00,30,""“Reducer action”, “SIDE_MENU_TOGGLE”"
04-10T18:06:56,30,""“Reducer action”, “NAV_GO, Note”"
04-10T18:06:55,30,""“Settings have been saved.”"
04-10T18:06:53,30,""“Reducer action”, “NOTE_UPDATE_ALL”"
04-10T18:06:52,30,""“Saving settings…”"
04-10T18:06:52,30,""“Reducer action”, “NOTE_UPDATE_ALL”"
04-10T18:06:52,30,""“Reducer action”, “SETTING_UPDATE_ONE”"
04-10T18:06:51,30,""“Reducer action”, “SIDE_MENU_CLOSE”"
04-10T18:06:51,30,""“Reducer action”, “NAV_GO, Notes”"
04-10T18:06:44,30,""“SearchEngine: Updated FTS table in 773ms”"
04-10T18:06:44,30,""“Settings have been saved.”"
04-10T18:06:44,30,""“Saving settings…”"
04-10T18:06:44,30,""“Reducer action”, “SETTING_UPDATE_ONE”"
04-10T18:06:44,30,""“Reducer action”, “FOLDER_UPDATE_ALL”"
04-10T18:06:44,30,""“Reducer action”, “SYNC_COMPLETED”"
04-10T18:06:44,30,""“Total resources: 713"”
04-10T18:06:44,30,""“Total notes: 150"”
04-10T18:06:44,30,""“Total folders: 33"”
04-10T18:06:44,30,""“fetchingTotal: -”"
04-10T18:06:44,30,""“Operations completed: “”
04-10T18:06:43,30,”"“SearchEngine: Updating FTS table…”"
04-10T18:06:43,30,""“Reducer action”, “SETTING_UPDATE_ONE”"
04-10T18:06:39,30,""“Settings have been saved.”"
04-10T18:06:38,30,""“Reducer action”, “SYNC_STARTED”"
04-10T18:06:38,30,""“Starting scheduled sync”"
04-10T18:06:38,30,""“Preparing scheduled sync”"
04-10T18:06:38,30,""“Scheduling sync operation…”"
04-10T18:06:36,30,""“Reducer action”, “DECRYPTION_WORKER_SET”"
04-10T18:06:36,30,""“DecryptionWorker: completed decryption.”"
04-10T18:06:35,30,""“Scheduling sync operation…”"
04-10T18:06:35,30,""“Reducer action”, “EVENT_NOTE_ALARM_FIELD_CHANGE”"
04-10T18:06:35,30,""“Reducer action”, “NOTE_UPDATE_ONE”"
04-10T18:06:34,30,""“Reducer action”, “DECRYPTION_WORKER_SET”"
04-10T18:06:34,30,""“Saving settings…”"
04-10T18:06:33,30,""“Reducer action”, “DECRYPTION_WORKER_SET”"
04-10T18:06:33,30,""“DecryptionWorker: starting decryption…”"
04-10T18:06:33,30,""“Reducer action”, “SIDE_MENU_OPEN”"
04-10T18:06:33,30,""“Reducer action”, “SIDE_MENU_TOGGLE”"
04-10T18:06:33,30,""“Reducer action”, “FOLDER_UPDATE_ALL”"
04-10T18:06:33,30,""“Reducer action”, “SETTING_UPDATE_ONE”"
04-10T18:06:32,30,""“Reducer action”, “SYNC_COMPLETED”"
04-10T18:06:32,30,""“Total resources: 713"”
04-10T18:06:32,30,""“Total notes: 150"”
04-10T18:06:32,30,""“Total folders: 33"”
04-10T18:06:32,30,""“createLocal: 1"”
04-10T18:06:32,30,""“fetchingTotal: 1"”
04-10T18:06:32,30,""“Operations completed: “”
04-10T18:06:32,30,”"“Reducer action”, “SETTING_UPDATE_ONE”"
04-10T18:06:32,30,""“Reducer action”, “SYNC_GOT_ENCRYPTED_ITEM”"
04-10T18:06:32,30,""“Reducer action”, “EVENT_NOTE_ALARM_FIELD_CHANGE”"
04-10T18:06:32,30,""“Reducer action”, “NOTE_UPDATE_ONE”"
04-10T18:06:28,30,""“ResourceService::deleteOrphanResources:”, “[]”"
04-10T18:06:28,30,""“ResourceService::indexNoteResources: Completed”"
04-10T18:06:28,30,""“Settings have been saved.”"
04-10T18:06:28,30,""“Saving settings…”"
04-10T18:06:28,30,""“Reducer action”, “SETTING_UPDATE_ONE”"
04-10T18:06:27,30,""“Reducer action”, “NOTE_UPDATE_ALL”"
04-10T18:06:27,30,""“Synchronisation is already in progress. State: in_progress”"
04-10T18:06:27,30,""“Starting scheduled sync”"
04-10T18:06:27,30,""“Preparing scheduled sync”"
04-10T18:06:27,30,""“Scheduling sync operation…”"
04-10T18:06:27,30,""“Running background sync on timer…”"
04-10T18:06:27,30,""“ResourceService::indexNoteResources: Start”"
04-10T14:37:12,30,""“Reducer action”, “NOTE_UPDATE_ALL”"
04-10T14:37:11,30,""“Reducer action”, “SYNC_STARTED”"
04-10T14:37:11,30,""“Starting scheduled sync”"
04-10T14:37:11,30,""“Preparing scheduled sync”"
04-10T14:37:11,30,""“Scheduling sync operation…”"
04-10T14:37:11,30,""“Running background sync on timer…”"
04-10T14:32:09,30,""“Reducer action”, “NAV_BACK”"
04-10T14:31:57,30,""“Reducer action”, “SIDE_MENU_CLOSE”"
04-10T14:31:54,30,""“Reducer action”, “SIDE_MENU_OPEN”"
04-10T14:31:54,30,""“Reducer action”, “SIDE_MENU_TOGGLE”"
04-10T14:31:50,30,""“Reducer action”, “SIDE_MENU_CLOSE”"
04-10T14:31:44,30,""“Reducer action”, “SIDE_MENU_OPEN”"
04-10T14:31:44,30,""“Reducer action”, “SIDE_MENU_TOGGLE”"
04-10T14:31:42,30,""“Settings have been saved.”"
04-10T14:31:40,30,""“Reducer action”, “NOTE_UPDATE_ALL”"
04-10T14:31:39,30,""“Reducer action”, “NOTE_UPDATE_ALL”"
04-10T14:31:39,30,""“Saving settings…”"
04-10T14:31:39,30,""“Reducer action”, “SETTING_UPDATE_ONE”"
04-10T14:31:38,30,""“Reducer action”, “SIDE_MENU_CLOSE”"
04-10T14:31:38,30,""“Reducer action”, “NAV_GO, Notes”"
04-10T14:31:32,30,""“Reducer action”, “SIDE_MENU_OPEN”"
04-10T14:31:32,30,""“Reducer action”, “SIDE_MENU_TOGGLE”"
04-10T14:31:24,30,""“Reducer action”, “NAV_GO, Note”"
04-10T14:31:22,30,""“Reducer action”, “NAV_BACK”"
04-10T14:31:08,30,""“Settings have been saved.”"
04-10T14:31:07,30,""“Reducer action”, “NAV_GO, Note”"
04-10T14:31:06,30,""“Reducer action”, “NOTE_UPDATE_ALL”"
04-10T14:31:05,30,""“Saving settings…”"
04-10T14:31:05,30,""“Reducer action”, “NOTE_UPDATE_ALL”"
