BUG ? - plugin TEMPLATES and tags
If this is a bug report, please create it on GitHub instead. Follow this link:
on
Joplin 3.7.9 (prod, linux)
Appareil : linux, Intel(R) Celeron(R) N4020 CPU @ 1.10GHz
ID client : de3faf1691004ef0982e9f2aac6cfe13
Version de Synchro : 3
Version du profil : 53
Trousseau supporté : Non
ID d'instance alternatif : -
Sync target: (Aucun)
Éditeur : Markdown
Révision : d58a0bb
Backup: 1.5.1
Convert Text To New Note: 1.5.1
Favorites: 1.3.2
Home Note: 2.1.2
Hotfolder: 1.2.3
joplin-hotkey: 1.0.0
joplin-plugin-cjk-breaks: 1.0.2
Paginator: 3.0.2
Record: 1.5.0
Tagging: 1.0.3
Templates: 3.0.0
Bug or forbidden name ?
I create notes using the TEMPLATES 3.0 plugin with Joplin 3.7.9 on Kubuntu 26.04.
In the note used as a template, I added some tags. When a note is created, these tags are correctly applied except for one: "P_". Instead, the tag "pc" is created !
Have you experienced the same issue?
Could be "P_" a reserved word in the code ?
Thanks
Just for information I have tried this on Linux and Windows machines using Joplin 3.6 and 3.7 and I cannot reproduce this. I have also tried it when the pc tag does not already exist and also when it does. The tags still appear as defined in the template.
The only thing I can suggest is to switch off all plugins apart from "Templates" and see if it still occurs.
