Best way to change sync to joplin
If you are not sure if it's a bug or not, PLEASE POST ON GITHUB ANYWAY.
windows 11
syncing onedrive
want to sync between windows and android
joplin 2.9.17
If you can also please provide a log, as described here: How to enable debugging | Joplin
Looking for the safest way to change sync from onedrive to joplin sync.
Thanks
On Joplin Desktop
  1. Sync all your devices with your old cloud
  2. Create .JEX backup of all notes
  3. Change sync to Joplin Cloud
  4. `Menu --> Tools --> Options --> Sync --> Re-upload local data to sync target". Wait for completion
  5. Change sync target on mobile devices, test the sync
  6. done
