I just fetched the latest from master but Joplin is not starting up when I run the AppImage on Ubuntu 1804. I’m not sure which merge is related, but it was working yesterday.
It does run if I use the run.sh script.
The electron-builder is broken and removes node_modules directories from subdirs (in our case the jopli-renderer).
We are in the process of finding a workaround. Building the app is currently not possible.
For now you can build the AppImage with electron-builder 20.15.0
Thank you. Just wanted to alert you to it early, in case you were unaware.
BTW still broken as of c4fb5b72cde84dbccbd29dd986526bdf2a6719ce
It’s working again! Great work guys! And it’s pretty snappy too.
