Say I write this-:
- abcd
- efgh
- ijkl
Then say I write
- abcd
This above line gets auto numbered as "4) abcd". How do I avoid getting this? Is there a way to do it. It is really ruining my experience of Joplin.
Say I write this-:
Then say I write
You didn't write this because if I copy and paste it into Joplin it works fine. If something doesn't work, you shouldn't copy and paste it exactly as it is in Joplin.
I would guess that when the OP says
Then say I write
This is the method being described and not part of the text entry.
The OP is possibly referring to the fact it appears that a numbered list cannot follow a numbered list no matter how many new lines there are between them. There has to be something else inserted between them to trigger a new list. If not, the spaces are collapsed and the numbering continues uninterrupted.
I think if you leave the period out after the numbers, then it doesn't become a markdown list.
Or put something "invisible" between the lists.
Also note that the numbers used in the markdown for numbered lists have no importance apart from the first one in a list. The list will count up from that first number.
