Android not sync'ing
I use Joplin on 3 devices (1 x linux Manjaoro, Joplin 2.7.14, 1 x Win10, Joplin 2.7.15 and Android 11, Joplin 2.7.2). on a box.com webdav account.
Both Monjaro and Windows works and sync fine, but Android doesn't. When launched, I can see the sync process run, but at the end, no note is dispayed,
Webdav path/ID/passwd are double checked, Android app permissions are ok (Cam, file access and localization).
What else should I check ?
Thanks
Diego
