Joplin Cloud
I'm receiving error message: "An error occurred: Renderer process gone." I receive the error immediately when Joplin is started and I have to Quit or Restart in Safe Mode. Safe Mode has the same behavior. I'm unable to pull bug reports via the usual debugging process or access any menus because Joplin will not fully load.
I read posts on the topic (sorry, I can't include links in this post but I did read some).
Laurent mentions in one of them a fix in the next 2.14 patch. I had thought that was 2.14.19 but I had this error on 2.14.20.
The problem first started when Joplin struggled to sync a note to Joplin Cloud. Joplin never recovered from that. The note wasn't anything elaborate, just an old email that was forwarded to Joplin.
Is there any way to work around this error in order to access the notes, even if it's in raw form? I entered in some very important data in the past hour or so and need to access that data. I'm not overly concerned with anything prior to today as I backup daily but the data I entered is very important and somewhat timely. Any thoughts on accessing it would be greatly appreciated. Thanks!
