Hi all,
Many of us using Joplin and LLMs for our daily workflow have felt the need to integrate both. However, finding a balance isn't easy.
Usually, I am dealing with two extremes:
- Using plugins that require LLMs APIs and, a subscriptions.
- Implementing MCP, which is not simple and doesn't align with everyday tasks.
In my search for a practical integration that avoids hardware limitations or technical hurdles, I’ve found a "middle ground", so far.
While it’s not a 100% private or integrated, it is a highly effective way to work. At least for me.
The Setup: Antigravity + Joplin Token
I use Antigravity to manage my notes via the Joplin API.
Since my daily notes aren't highly sensitive, leveraging a free cloud-based models allows me to bypass the need for the latest hardware to run local LLMs.
This approach allows the Antigravity to handle the "heavy lifting" almost autonomously:
- Note Consolidation: It merges scattered, outdated fragments into structured "Master Notes."
- Smart Hierarchy: It fixes the "messy inbox" problem by moving notes to logical folders.
- Automated Content: It can research and create technical notes from scratch with proper Markdown formatting.
- Tag Management: It keeps the tagging system clean and consistent.
Beside others good features,
Why not MCP?
I want to clarify that my use case is personal and everyday. I feel MCP is perfect for a different level of requirement that doesn't necessarily fit a simple, daily routine.
This "indirect" collaboration via Joplin Token is a much faster and more accessible workaround for a "smart" Joplin.
Am I wrong? or, Have you found a simpler or better way to achieve this kind of integration? If so, please let me know!
